- To:
- Subject: Re: [cgal-discuss] Datasets
- Date: Tue, 12 Dec 2017 17:18:49 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Did you look into the data directory of the Polyhedron demo?
CGAL/demo/Polyhedron_3/data
You can also look at Thingi10K dataset:
https://ten-thousand-models.appspot.com/
Sebastien.
On 12/12/2017 03:56 PM, Barnabe FALIU wrote:
Hello everyone,
I am encountering troubles to find appropriate datasets (clean .off file _without_ boundaries, zero-area faces, non-manifold edges,…) to use Boolean operators (intersection, difference, union…).
Do you have a dataset to suggest?
I tried this one from Princeton University: http://modelnet.cs.princeton.edu/ but I am still getting “unclean” meshes.
Thank you for your help.
*Barnabé FALIU*
*Doctorant en Informatique**,**ISEN-Toulon*
Place Georges Pompidou - 83000 Toulon
Tel : _+33 (0)6 20 82 25 78_
E-mail:
<mailto:>
Siret N 383 386 877 000 39
Code Naf : 8542 Z
- [cgal-discuss] Datasets, Barnabe FALIU, 12/12/2017
- Re: [cgal-discuss] Datasets, Sebastien Loriot (GeometryFactory), 12/12/2017
