- To: "" <>
- Subject: Re: [cgal-discuss] Any code, any sugestion about union 2d?
- Date: Tue, 19 Dec 2017 16:40:31 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
W dniu 2017-12-19 10:16:26 użytkownik Sebastien Loriot (GeometryFactory)
napisał:
> You can look at this example:
> https://doc.cgal.org/latest/Boolean_set_operations_2/Boolean_set_operations_2_2simple_join_intersect_8cpp-example.html
This code have trouble. This is not a path. only polygon I can use. how
using arc or bezier?
This code no have makefile. where is #include "print_utils.h"
How I can start?
> Sebastien.
> On 12/19/2017 09:41 AM, xoru wrote:
> > Hello,
> > What I can start using union 2d?
> > For example I have a 7 boxs. How add (union) all rectangles and get
> > one rectangle and hole inside?
> > I'm beginer. Where is any example with makefile and tutorial?
> > Thanks
> > Xor
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Any code, any sugestion about union 2d?, xoru, 12/19/2017
- Re: [cgal-discuss] Any code, any sugestion about union 2d?, Sebastien Loriot (GeometryFactory), 12/19/2017
- <Possible follow-up(s)>
- Re: [cgal-discuss] Any code, any sugestion about union 2d?, xoru, 12/19/2017
