cgal-discuss - Re: [cgal-discuss] Error compiling cgal.
  • To:
  • Subject: Re: [cgal-discuss] Error compiling cgal.
  • Date: Sun, 24 Dec 2017 18:04:28 +0530
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
thank you
On Sun, Dec 24, 2017 at 12:26 AM, nolvis <> wrote:
I found a solution. I was using inĀ  cmakelists.txt cgal_use_file and when i
manually added my own libraries that i use in cmakelists.txt it worked
perfectly.
thanks and regardsĀ
mobile:9163016823
