- To: "" <>
- Subject: [cgal-discuss] how create and clear
- Date: Thu, 04 Jan 2018 23:54:59 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I have 2 polygons. outer and hole inside outer.
Polygon_2 outer ;
outer.push_back( Point(-1,-1) ) ;
outer.push_back( Point(0,-12) ) ;
outer.push_back( Point(1,-1) ) ;
outer.push_back( Point(12,0) ) ;
outer.push_back( Point(1,1) ) ;
outer.push_back( Point(0,12) ) ;
outer.push_back( Point(-1,1) ) ;
outer.push_back( Point(-12,0) ) ;
Polygon_2 hole ;
hole.push_back( Point(-1,0) ) ;
hole.push_back( Point(0,1 ) ) ;
hole.push_back( Point(1,0 ) ) ;
hole.push_back( Point(0,-1) ) ;
Polygon_with_holes poly( outer ) ;
poly.add_hole( hole ) ;
1. How I can create poly variable without initialization.
Polygon_with_holes poly;
and how add outer to poly?
is any poly.add_outer function?
2. How I can clear all point from poly. all outer and all holes?
poly.clear() or similar?
- [cgal-discuss] how create and clear, xoru, 01/04/2018
- Re: [cgal-discuss] how create and clear, Efi Fogel, 01/05/2018
- <Possible follow-up(s)>
- Re: [cgal-discuss] how create and clear, xoru, 01/05/2018
