cgal-discuss - Re: [cgal-discuss] memory leak in simple code
  • To: "" <>
  • Subject: Re: [cgal-discuss] memory leak in simple code
  • Date: Thu, 11 Jan 2018 19:23:58 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:4fDKbBQ9A0sjX0UC/kM0E7ho6dpsv+yvbD5Q0YIujvd0So/mwa69bByN2/xhgRfzUJnB7Loc0qyK6/mmATRIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfa5+IA+qoQnNq8IbnZZsJqEtxxXTv3BGYf5WxWRmJVKSmxbz+MK994N9/ipTpvws6ddOXb31cKokQ7NYCi8mM30u683wqRbDVwqP6WACXWgQjxFFHhLK7BD+Xpf2ryv6qu9w0zSUMMHqUbw5Xymp4qF2QxHqlSgHLSY0/mHNhMJugqxVoxWvqQFkzo7IeYGZKOZyc7nBcd4YQ2dKQ8ZfVzZGAoO5d4YOAO0BPfxFr4LgoFYPohy+BROxBO70zT9IgGH53bEg3+Q5FQHLxQotFM8AvnTTqdX6LqYSUeatwanJyzXDdfJW1i3n5IjGaBAsp+yHU7FoccfJ10UjCg3Igk+NpYHmIz+ZzPkBvmef4uZ6SO6ii24qpxlsrjWsxsogkJTFipwXx1ze6Cl13pg5KcelREN6YtOpFoZbuTuAOItsWMwiRnlluCYkxb0Cvp62ZDMKyJE7xx7HbPyKd4yF7gj7VOaWPTh5hW5ld6ilixa190iv1PH8WtOs0FZOtiZFk9/MuW4R1xHL9MSLV/Vw8l281TuMywzf8PxILE8wmKbBNpIswr49moIWsUvZHy/2nEv2jLWRdkUh4uWp5OPnYq/7ppKHMI90jB/xMrg0lsynBeQ0KhIOUHSD+eSgyL3j+lX0T6lFjvIslqnVqY3VJcUApqGlHg9VyZ0j5g2kDzam1dQYhWMIIEhEeBKBlYjpOkvBLOr2Dfel0ByRlix2zaXGIqH5GceKaWPSla/oO7d78U9VjgQpistO4opdTbAHLvW0UUD4sJnUDwQyLhevkNrgXZ922YoaHG6OGaSEK7j6sFmS5+tpLfPGLNsetz/5bvQk/PXzlmQRmFkHfKDv04FBO16iGfEzM0KDfDK4ktAbDE8NuAciCvTu3g7RGQVPbmq/CvpvrgowD5irWN+aF9KdxYeZ1SL+JaV4I2VPC1SCC3DtJteDXfoQLjqWcJY4zm40EIO5Qopk7imA8Rfgwus1KezZ5msAscC7jYUn16jojRg3sAdMIYGd3mWKFT0mhWYUXzhnjeZnpkdv1l7F1q51n7pAEY4L6g==
Many thanks
W dniu 2018-01-11 18:10:40 użytkownik Sebastien Loriot (GeometryFactory)
napisał:
> There is a known issue with valgrind when the rounding mode is changed,
> so the report of Valgrind is not correct.
> If you compile with -fsanitize=address you will see that there is no
> leak reported.
> Sebastien.
> On 01/11/2018 06:01 PM, xoru wrote:
> > I have one function
> > void spr()
> > Polygon_2 P;
> >  P.push_back (Point_2 (0, 0));
> >  P.push_back (Point_2 (1, 0));
> >  P.push_back (Point_2 (1, 1));
> >  P.push_back (Point_2 (0, 1));
> > std::cout << "ilość punktów =" << P.size() << "\n";
> > I get memory leak 4 words
> > How I can leave memory?
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
