Re: [cgal-discuss] Getting error "BOOST_PARAMETER_MAX_ARITY must be at least 12 for CGAL::Mesh_3" in CGAL 4.9
- To:
- Subject: Re: [cgal-discuss] Getting error "BOOST_PARAMETER_MAX_ARITY must be at least 12 for CGAL::Mesh_3" in CGAL 4.9
- Date: Mon, 15 Jan 2018 11:20:33 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
try defining BOOST_PARAMETER_MAX_ARITY to 12 before including any header from boost.
Sebastien.
On 01/14/2018 07:17 PM, biswajitcse wrote:
While I want to create an implicit iso-surface from a point set, I have got "BOOST_PARAMETER_MAX_ARITY must be at least 12 CGAL::Mesh_3" under global_parameter.h error. I am using CGAL4.10 and Boost 1.65 in Windows 10 64 bits OS. How can I resolve this? please give any idea. Thank you.
Sent from the cgal-discuss mailing list archive <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- Re: [cgal-discuss] Getting error "BOOST_PARAMETER_MAX_ARITY must be at least 12 for CGAL::Mesh_3" in CGAL 4.9, biswajitcse, 01/14/2018
- Re: [cgal-discuss] Getting error "BOOST_PARAMETER_MAX_ARITY must be at least 12 for CGAL::Mesh_3" in CGAL 4.9, Sebastien Loriot (GeometryFactory), 01/15/2018
- Re: [cgal-discuss] Getting error "BOOST_PARAMETER_MAX_ARITY must be at least 12 for CGAL::Mesh_3" in CGAL 4.9, Biswajit Biswas, 01/15/2018
