- To:
- Subject: Re: [cgal-discuss] CGAL surface mesh - modify vertex coordinates
- Date: Mon, 29 Jan 2018 17:28:44 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:Rrl3uRDU1E4QxSq+mcfcUyQJP3N1i/DPJgcQr6AfoPdwSPT8p8bcNUDSrc9gkEXOFd2Cra4c0qyO6+jJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglUmTaxe69+IAmrpgjNq8cahpdvJLwswRXTuHtIfOpWxWJsJV2Nmhv3+9m98p1+/SlOovwt78FPX7n0cKQ+VrxYES8pM3sp683xtBnMVhWA630BWWgLiBVIAgzF7BbnXpfttybxq+Rw1DWGMcDwULs7Xiiv4qlpRRLmkSsLKzE0+3zThsFwkK5XpRSsrAF9zYHJeoGYLOdwcL3Tfd0aRmRPUMheWCNDDYygYIUCFPYBMORCooXhu1cDoxmzCA+xD+3v0D9IgXr20LU03+o8Dw7JxxYvH8kSsHTVstr1MroZX+ayzKnSzDXDaO9W0ir55IbJbB8hpvSMUqxsccrLyUghFxnKgUmMqYziJTOU1uEBv2aG5OdnTuKvj2knqxtwojio2scgkIzJhoYOx1DL8CV22oc1JdmiREFnZt6kFYJduieHPIV4RcMiRntnuCc8yrAev560ZjMFx48jxxHBcfCIb4+I4hflWe2MIjl4nGpodbCwihqo7ESs1O3xWtO33VpUtCZIndjBumgP2hHQ8MSLVPRw80a71TqS0w3e5PtILEI0mKfdNpUv2KQ/loAJvkTGBiL2mFv5jKuRdkg8/+in8eXnYrH/qp6SMo94lhjyMqohl8G+G+g4PQ8OX2+U+eS4yrLv51H2QLJPjvEuk6nZto7VJdgDq6O7DAJZyJsv5wi/Aju809kUg2MLIV1EdR6fiojmIVDOIPT2DfelhFSslS9mx+vCPr3mGJXNL3/DkKv7cbZ4705R0wUzzdVF6JJVDrENOu78Wkj0tNDAFB82LxS0w/r7CNV6zo4RRW2PDbWdMK/LrFCI5/kvLPWRZI8OozbwMOMl5v7rjX8hg1ARZ6ip3Z0NaHC5BPtqOUuZYWC/yusGRGwFtw57QO3xg0CZShZSYWyzVuQy/GIVEoWjWM34S4qkm6CA0SHzOppMZ2daQhCjHHDtepmeStkFYz6VON4g2HRQTrymUY4myVersCf1zrNmKqzf/ShO5sGr78R8++CGzUJ6zjdzFcnIjjnUHjNE21gQTjpz55hR5El0y1ONy6992qUKGtla5vcPWQA/Z8eFk75KTuvqUweERe+nDU68S4z/Uz40R9M1hdQJZhQlQojwvlX4xyOvRoQtufmLCZgzqP+O2nHwI4Nizi6D2vV/yVYhRcRLOCutgastrwU=
This should be working
(try reading the point again and put an assertion to check it if
you want to convince yourself).
The problem should be somewhere else.
Sebastien.
On 01/29/2018 05:03 PM, nolvis wrote:
How do i modify CGAL surface mesh vertex index coordinates? For now i've
been trying to change coordinates of vertices like this:
for (auto vertex_iterator : mesh.vertices()) {
Point_3 p(1,0,1);
mesh.point(vertex_iterator) = p;
Code above is just a sample, i'm not assigning same coordinates to all
vertices.
After i try to do caluclations with it i get undefined results.
- [cgal-discuss] CGAL surface mesh - modify vertex coordinates, nolvis, 01/29/2018
- Re: [cgal-discuss] CGAL surface mesh - modify vertex coordinates, Sebastien Loriot (GeometryFactory), 01/29/2018
