- To: "" <>
- Subject: AW: [cgal-discuss] Multithreading support
- Date: Mon, 29 Jan 2018 17:34:19 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
HI Sebastian,
ok, this sounds like a limitation. Is Surface_Mesh a kernel without filtered
constructions and reference counting?
Or maybe I misunderstood you.
Best regards
Torge
> -----Ursprüngliche Nachricht-----
> Von:
> [mailto:]
> Im
> Auftrag von Sebastien Loriot (GeometryFactory)
> Gesendet: Montag, 29. Januar 2018 17:57
> An:
> Betreff: Re: [cgal-discuss] Multithreading support
> If you use a kernel without filtered constructions or reference counting,
> then
> you shouldn't have a problem provided mesh A and mesh B are different.
> Sebastien.
> On 01/29/2018 05:47 PM, Riedel, Torge wrote:
> > Hi,
> > one more question: Is CGAL multithreading safe? To be more precise:
> > Can I operate in one thread on mesh A and operate in another thread on
> > mesh B? Sure I will need sync-objects when operating on the same mesh.
> > But is it safe to operate on different objects without any problems in
> > different threads?
> > Thank you very much.
> > Torge
> > CENIT AG, Industriestrasse 52-54, 70565 Stuttgart, Tel.: +49 711
> > 7825-30, Fax: +49 711 7825-4000, Internet: www.cenit.com
> > Geschaeftsstellen: Berlin, Frankfurt, Hamburg, Hannover, Muenchen,
> > Oelsnitz, Ratingen, Saarbruecken
> > Vorstandsmitglieder: Kurt Bengel, Matthias Schmidt
> > Aufsichtsratsmitglieder: Andreas Schmidt (Vorsitzender des
> > Aufsichtsrats), Hubert Leypoldt, Andreas Karrer
> > Bankverbindungen:
> > Deutsche Bank (BLZ 600 700 70) Kto. 1661 040 IBAN : DE85 6007 0070
> > 0166
> > 1040 00 SWIFT-CODE : DEUTDESS,
> > Commerzbank (BLZ 600 400 71) Kto. 532 015 500 IBAN : DE83 6004 0071
> > 0532
> > 0155 00 SWIFT-Code : COBADEFF600,
> > Registergericht: Amtsgericht Stuttgart
> > Handelsregister: HRB Nr. 19117
> > Umsatzsteuer: ID-Nr. DE 147 862 777
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
CENIT AG, Industriestrasse 52-54, 70565 Stuttgart, Tel.: +49 711 7825-30,
Geschaeftsstellen: Berlin, Frankfurt, Hamburg, Hannover, Muenchen, Oelsnitz,
Aufsichtsratsmitglieder: Andreas Schmidt (Vorsitzender des Aufsichtsrats),
Bankverbindungen:
Deutsche Bank (BLZ 600 700 70) Kto. 1661 040 IBAN : DE85 6007 0070 0166 1040
Commerzbank (BLZ 600 400 71) Kto. 532 015 500 IBAN : DE83 6004 0071 0532 0155
- [cgal-discuss] Multithreading support, Riedel, Torge, 01/29/2018
- Re: [cgal-discuss] Multithreading support, Sebastien Loriot (GeometryFactory), 01/29/2018
- AW: [cgal-discuss] Multithreading support, Riedel, Torge, 01/29/2018
- Re: [cgal-discuss] Multithreading support, Andreas Fabri, 01/29/2018
- Re: [cgal-discuss] Multithreading support, Biswajit Biswas, 01/29/2018
