cgal-discuss - AW: [cgal-discuss] Support for stl files
  • To: "" <>
  • Subject: AW: [cgal-discuss] Support for stl files
  • Date: Fri, 9 Feb 2018 08:57:43 +0000
  • Accept-language: de-DE, en-US
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-phdr: 9a23:CNJqKxVFu5AM63vprP++tXC0CxPV8LGtZVwlr6E/grcLSJyIuqrYbBOFt8tkgFKBZ4jH8fUM07OQ7/i5HzRYqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjWwba9vIBmssQndqtQdjJd/JKo21hbHuGZDdf5MxWNvK1KTnhL86dm18ZV+7SleuO8v+tBZX6nicKs2UbJXDDI9M2Ao/8LrrgXMTRGO5nQHTGoblAdDDhXf4xH7WpfxtTb6tvZ41SKHM8D6Uaw4VDK/5KptVRTmijoINyQh/W/XlMJ+kb5brhyiqRxxwYHUYZ2aO/VxcK7GYdMaXHBMUtpNWyBdH4+xaZYEAeobPeZfqonwv1UCowe/BQayGezg1DtIimfr1qMk1OQhCw7G0xIuE9kTt3nass/5OrsTUe+r0abH0zHDYuhK1jjj7ojIcwwhreuRUr1uaMfcz1QkGQ3CjlWVs4PlPjWV2/wMs2id9epgVPigh3QpqwFrujSg2tkjio/IhoIJ0FzL6SJ5wIMzKNalS0B7ecapHIZUuiyULYd6X8AvTmJytConyrALvYS3cScSxJg62xLTceCLf5KV7h75SeqdPSt0iXR4c7ylnRmy61KvyujkW8m0zllKqi1Fn8HJtnECyxDf99KLRedj8Uen2DaPyxrf5f1DIUAxjabbKpghzaAslpcLrEjOGiH7lF/rgKKVdUgo4PWk5uTjb7n8qZKQL4p0hRv/MqQqlMy/G+M4Mg0WUmiD4+S8yqbj8FX5TbhIk/E7lrTWvIzYKMkaoqO0GxFb3pw/5Ra+ETipzcoXnX0cIV1ZZh2HiYnpO03ULP/lE/izm06snytzx/DaIr3hBY3AIWTMkLj7ebZx8lNTyAsozd9D+pJUEaoBLenoWk7xsdzYFgU2Pxa1w+bhEtV915kRVXiBAq+DY+vvt0SV7LcvP/WUf91S/y3sLuAsof/ol34w31EHOrK42IMeL3G+EPMhKEqQZT/gg8wKDHwR7TY5Gabhh1SGFDJSfH2vRLkU5zchCYvgA52JDtSmj7WFmSu6BZZLfXtuC1aWEH6ueZ/SCNkWbyfHaPVgnzAJUfzpd4g72hzk/FvGjYBmI+bZ/gUTuJTiyJ556ruAxlkJ6TVoApHFgCm2RGZukzZQHm5k7OVEuUV4j2y7/+19iv1cG8ZU4qoRAAw3M5/AieB3WYmrBlDxO+yRQVPjee2IRCkrR4tpkdQDZUdhXdmv3EiagniaRoQNnrnOP6Qat6LR23+oeZR42y6fkqIsiVg6BMBIMD//iw==
Hi,
Thank you very much. I think I searched in the wrong place.
Nevertheless I was not able to read my STL since it is in binary format.
(File starts with "solid binary"). CGAL::read_STL continues reading it and
does not stop. So maybe there is a check missing for binary format.
Any chance to read binary STL files with CGAL?
Kind regards
Torge
> -----Ursprüngliche Nachricht-----
> Von:
> [mailto:]
> Im
> Auftrag von Andreas Fabri
> Gesendet: Freitag, 9. Februar 2018 08:04
> An:
> Betreff: Re: [cgal-discuss] Support for stl files
> Hello,
> You can call
> bool
> read_STL( std::istream& input,
> std::vector< cpp11::array<double,3> >& points,
> std::vector< cpp11::array<int,3> >& facets,
> bool verbose = false)
> in
> CGAL-4.11/include/CGAL/IO/STL_reader.h
> std::ifstream input(argv[1], std::ios::binary);
> std::vector< CGAL::cpp11::array<double,3> > points;
> std::vector< CGAL::cpp11::array<int,3> > triangles;
> CGAL::read_STL(input,
> points,
> triangles);
> std::cout << points.size() << " " << triangles.size() << std::endl;
> Mesh m;
> if
> (CGAL::Polygon_mesh_processing::is_polygon_soup_a_polygon_mesh(trian
> gles)){
> std::cout << "it is a polygon mesh" << std::endl;
> CGAL::Polygon_mesh_processing::polygon_soup_to_polygon_mesh(points,
> triangles, m);
> Best regards,
> Andreas
> On 2/8/2018 4:19 PM, Riedel, Torge wrote:
> > Hi,
> > is there an api in cgal framework for reading / writing stl files? I
> > have found api for reading / writing OFF data. My evaluation file is
> > in stl format.
> > Kind regards
> > Torge
> > CENIT AG, Industriestrasse 52-54, 70565 Stuttgart, Tel.: +49 711
> > 7825-30, Fax: +49 711 7825-4000, Internet: www.cenit.com
> > Geschaeftsstellen: Berlin, Frankfurt, Hamburg, Hannover, Muenchen,
> > Oelsnitz, Ratingen, Saarbruecken
> > Vorstandsmitglieder: Kurt Bengel, Matthias Schmidt
> > Aufsichtsratsmitglieder: Andreas Schmidt (Vorsitzender des
> > Aufsichtsrats), Hubert Leypoldt, Andreas Karrer
> > Bankverbindungen:
> > Deutsche Bank (BLZ 600 700 70) Kto. 1661 040 IBAN : DE85 6007 0070
> > 0166
> > 1040 00 SWIFT-CODE : DEUTDESS,
> > Commerzbank (BLZ 600 400 71) Kto. 532 015 500 IBAN : DE83 6004 0071
> > 0532
> > 0155 00 SWIFT-Code : COBADEFF600,
> > Registergericht: Amtsgericht Stuttgart
> > Handelsregister: HRB Nr. 19117
> > Umsatzsteuer: ID-Nr. DE 147 862 777
> Andreas Fabri, PhD
> Chief Officer, GeometryFactory
> Editor, The CGAL Project
> phone: +33.492.954.912 skype: andreas.fabri
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
CENIT AG, Industriestrasse 52-54, 70565 Stuttgart, Tel.: +49 711 7825-30,
Geschaeftsstellen: Berlin, Frankfurt, Hamburg, Hannover, Muenchen, Oelsnitz,
Aufsichtsratsmitglieder: Andreas Schmidt (Vorsitzender des Aufsichtsrats),
Bankverbindungen:
Deutsche Bank (BLZ 600 700 70) Kto. 1661 040 IBAN : DE85 6007 0070 0166 1040
Commerzbank (BLZ 600 400 71) Kto. 532 015 500 IBAN : DE83 6004 0071 0532 0155
