- To:
- Subject: [cgal-discuss] Issue in CGAL installation
- Date: Wed, 14 Feb 2018 21:52:06 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi,
I am new to CGAL and willing to work on the same but finding installation
error as follows : Kindly help.
(CGAL 4.0.2+QT4)
CGAL_MAJOR_VERSION=4
CGAL_MINOR_VERSION=0
CGAL_BUGFIX_VERSION=2
CGAL_SONAME_VERSION=9
CGAL_SOVERSION =9.0.0
CGAL_REFERENCE_CACHE_DIR=
Building shared libraries
Targetting Visual Studio 10 2010
Target build enviroment supports auto-linking
Using VC10 compiler.
Generator uses intermediate configuration directory: $(Configuration)
USING CMake version: 3.10.2
System: Windows
CMake Warning (dev) at CMakeLists.txt:416 (if):
Policy CMP0054 is not set: Only interpret if() arguments as variables or
keywords when unquoted. Run "cmake --help-policy CMP0054" for policy
details. Use the cmake_policy command to set the policy and suppress this
warning.
Quoted variables like "MSVC" will no longer be dereferenced when the
policy
is set to NEW. Since the policy is not set the OLD behavior will be used.
This warning is for project developers. Use -Wno-dev to suppress it.
Build type: Release
USING CXXFLAGS = '/DWIN32 /D_WINDOWS /W3 /GR /EHsc
-D_CRT_SECURE_NO_DEPRECATE -D_SCL_SECURE_NO_DEPRECATE
-D_CRT_SECURE_NO_WARNINGS -D_SCL_SECURE_NO_WARNINGS /fp:strict /fp:except-
/MD /O2 /Ob2 /DNDEBUG'
USING LDFLAGS = '/machine:X86 /INCREMENTAL:NO'
Found GMP: C:/CGAL-4.0.2/auxiliary/gmp/lib/libgmp-10.lib
Found MPFR: C:/CGAL-4.0.2/auxiliary/gmp/lib/libmpfr-4.lib
GMP include: C:/CGAL-4.0.2/auxiliary/gmp/include
GMP libraries: C:/CGAL-4.0.2/auxiliary/gmp/lib/libgmp-10.lib
GMP definitions:
USING GMP_VERSION = '5.0.1'
MPFR include: C:/CGAL-4.0.2/auxiliary/gmp/include
MPFR libraries: C:/CGAL-4.0.2/auxiliary/gmp/lib/libmpfr-4.lib
MPFR definitions:
USING MPFR_VERSION = '3.0.0'
Boost version: 1.54.0
Found the following Boost libraries:
thread
Boost include: C:/local/boost_1_54_0
Boost libraries:
optimized;C:/local/boost_1_54_0/lib32-msvc-10.0/boost_thread-vc100-mt-1_54.lib;debug;C:/local/boost_1_54_0/lib32-msvc-10.0/boost_thread-vc100-mt-gd-1_54.lib
Boost definitions:
USING BOOST_VERSION = '1.54.0'
Performing Test CGAL_CFG_ARRAY_MEMBER_INITIALIZATION_BUG - Failed
Performing Test CGAL_CFG_DENORMALS_COMPILE_BUG - Success
Performing Test CGAL_CFG_FPU_ROUNDING_MODE_UNWINDING_VC_BUG - Success
Performing Test CGAL_CFG_IEEE_754_BUG - Success
Performing Test CGAL_CFG_ISTREAM_INT_BUG - Success
Performing Test CGAL_CFG_LONGNAME_BUG - Failed
Performing Test CGAL_CFG_MATCHING_BUG_5 - Success
Performing Test CGAL_CFG_MATCHING_BUG_6 - Failed
Performing Test CGAL_CFG_NESTED_CLASS_FRIEND_DECLARATION_BUG - Failed
Performing Test CGAL_CFG_NO_CPP0X_ARRAY - Success
Performing Test CGAL_CFG_NO_CPP0X_AUTO - Success
Performing Test CGAL_CFG_NO_CPP0X_COPY_N - Success
Performing Test CGAL_CFG_NO_CPP0X_DECLTYPE - Success
Performing Test
CGAL_CFG_NO_CPP0X_DEFAULT_TEMPLATE_ARGUMENTS_FOR_FUNCTION_TEMPLATES - Failed
Performing Test CGAL_CFG_NO_CPP0X_DELEGATING_CONSTRUCTORS - Failed
Performing Test CGAL_CFG_NO_CPP0X_DELETED_AND_DEFAULT_FUNCTIONS - Failed
Performing Test CGAL_CFG_NO_CPP0X_INITIALIZER_LISTS - Failed
Performing Test CGAL_CFG_NO_CPP0X_ISFINITE - Failed
Performing Test CGAL_CFG_NO_CPP0X_LAMBDAS - Success
Performing Test CGAL_CFG_NO_CPP0X_LONG_LONG - Success
Performing Test CGAL_CFG_NO_CPP0X_NEXT_PREV - Success
Performing Test CGAL_CFG_NO_CPP0X_RVALUE_REFERENCE - Success
Performing Test CGAL_CFG_NO_CPP0X_STATIC_ASSERT - Success
Performing Test CGAL_CFG_NO_CPP0X_TUPLE - Success
Performing Test CGAL_CFG_NO_CPP0X_VARIADIC_TEMPLATES - Failed
Performing Test CGAL_CFG_NO_LIMITS - Success
Performing Test CGAL_CFG_NO_LOGICAL_OPERATORS_ALTERNATIVES - Failed
Performing Test CGAL_CFG_NO_MESSAGE_PRAGMA_BUG - Success
Performing Test CGAL_CFG_NO_NEXTAFTER - Failed
Performing Test CGAL_CFG_NO_STATEMENT_EXPRESSIONS - Failed
Performing Test CGAL_CFG_NO_STL - Success
Performing Test CGAL_CFG_NO_TMPL_IN_TMPL_PARAM - Success
Performing Test CGAL_CFG_NO_TR1_ARRAY - Failed
Performing Test CGAL_CFG_NO_TR1_TUPLE - Failed
Performing Test CGAL_CFG_NO_WARNING_CPP_DIRECTIVE_BUG - Failed
Performing Test CGAL_CFG_NUMERIC_LIMITS_BUG - Success
Performing Test CGAL_CFG_OUTOFLINE_MEMBER_DEFINITION_BUG - Success
Performing Test CGAL_CFG_TEMPLATE_IN_DEFAULT_PARAMETER_BUG - Success
Performing Test CGAL_CFG_TYPENAME_BEFORE_DEFAULT_ARGUMENT_BUG - Success
Performing Test CGAL_CFG_USING_BASE_MEMBER_BUG_2 - Success
Library config detected: /CMakeLists.txt
CMake Error at src/CMakeLists.txt:82 (add_subdirectory):
add_subdirectory given source "C:/CGAL-4.0.2/src/CGAL/CMakeLists.txt"
which
is not an existing directory.
Call Stack (most recent call first):
src/CMakeLists.txt:143 (configure_component)
Library config detected: Core/CMakeLists.txt
add_subdirectory given source "C:/CGAL-4.0.2/src/CGALCore/CMakeLists.txt"
which is not an existing directory.
Library config detected: ImageIO/CMakeLists.txt
"C:/CGAL-4.0.2/src/CGALImageIO/CMakeLists.txt" which is not an existing
directory.
Library config detected: Qt3/CMakeLists.txt
add_subdirectory given source "C:/CGAL-4.0.2/src/CGALQt3/CMakeLists.txt"
Library config detected: Qt4/CMakeLists.txt
add_subdirectory given source "C:/CGAL-4.0.2/src/CGALQt4/CMakeLists.txt"
Library configs detected:
/CMakeLists.txt;Core/CMakeLists.txt;ImageIO/CMakeLists.txt;Qt3/CMakeLists.txt;Qt4/CMakeLists.txt
Configuring incomplete, errors occurred!
See also "C:/CGAL-4.0.2/build/CMakeFiles/CMakeOutput.log".
See also "C:/CGAL-4.0.2/build/CMakeFiles/CMakeError.log".
- [cgal-discuss] Issue in CGAL installation, Dakshata, 02/15/2018
- Re: [cgal-discuss] Issue in CGAL installation, Laurent Rineau (CGAL/GeometryFactory), 02/19/2018
- Re: [cgal-discuss] Issue in CGAL installation, DAKSHATA PANCHAL, 02/19/2018
