- To:
- Subject: Re: [cgal-discuss] About Medial Axis Transform contributing
- Date: Wed, 21 Feb 2018 07:26:49 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
- Ironport-phdr: 9a23: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
Any update on your implementation of Q-MAT?
I'd be interested in seeing that as part of CGAL.
Jia Bill wrote
> I'm working on Q-MAT which stands for computing Medial Axis Transform
> (MAT) by Quadratic Error Minimization, an efficient way to calculate MAT.
> For detail, check here:
> http://cgcad.thss.tsinghua.edu.cn/wangbin/qmat/qmat.html
> Is this valuable and effective enough to contribute it into the CGAL repo.
> Also does it break the design goals if I use some of the algorithms
> already in the CGAL?
> I'm really new in contributing to such a well-known repo, so all
> suggestions are welcomed, especially about what I should do next.
> 发自网易邮箱大师
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- Re: [cgal-discuss] About Medial Axis Transform contributing, Stefan S., 02/21/2018
