- To:
- Subject: Re: [cgal-discuss] stl generation
- Date: Thu, 22 Feb 2018 08:57:30 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Nothing officially documented but the files CGAL/IO/STL_reader.h and
CGAL/IO/STL_writer.h provide minimal support of STL files.
Sebastien.
On 02/22/2018 07:34 AM, iampriyanshi wrote:
My project requires the generation of STL format files.
Is there any API to get STL files or build one?
- [cgal-discuss] stl generation, iampriyanshi, 02/22/2018
- Re: [cgal-discuss] stl generation, Sebastien Loriot (GeometryFactory), 02/22/2018
- Re: [cgal-discuss] stl generation, iampriyanshi, 02/22/2018
