cgal-discuss - Re: [cgal-discuss] CGAL 4.12 Beta 1 Released, Computational Geometry Algorithms Library
  • To:
  • Subject: Re: [cgal-discuss] CGAL 4.12 Beta 1 Released, Computational Geometry Algorithms Library
  • Date: Tue, 27 Feb 2018 21:13:50 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
On 27/02/2018 16:46, Laurent Rineau (CGAL/GeometryFactory) wrote:
> The CGAL project is a collaborative effort to develop a robust,
> easy-to-use, and efficient C++ software library of geometric data
> structures and algorithms, like
> - triangulations (2D constrained triangulations, Delaunay triangulations
> and periodic triangulations in 2D and 3D),
> - Voronoi diagrams (for 2D and 3D points, 2D additively weighted
> Voronoi diagrams, and segment Voronoi diagrams),
> - Boolean operations on polygons and polyhedra,
> - regularized Boolean operations on polygons with curved arcs
> - arrangements of curves,
> - mesh generation (2D, 3D and surface mesh generation,
> surface mesh subdivision and parametrization),
> - alpha shapes (in 2D and 3D),
> - convex hull algorithms (in 2D, 3D and dD),
> - operations on polygons (straight skeleton and offset polygon),
> - search structures (kd trees for nearest neighbor search, and
> range and segment trees),
> - interpolation (natural neighbor interpolation and placement of
> streamlines),
> - optimization algorithms (smallest enclosing sphere of points or
> spheres, smallest enclosing ellipsoid of points, principal
> component analysis),
> - kinetic data structures
Should KDS be removed there?
Maybe the whole list could be updated? I can look into it in parallel
with the small update to the website (mail about that... soon).
Mael
