Re: [cgal-discuss] Batched arrangment point location: which input point the query results refers to?
- To:
- Subject: Re: [cgal-discuss] Batched arrangment point location: which input point the query results refers to?
- Date: Thu, 1 Mar 2018 08:54:02 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
- Ironport-phdr: 9a23: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
Hello
I have the same problem. Does someone have a solution or a workaround ?
Have a Nice day
Florian Prud'homme
- Re: [cgal-discuss] Batched arrangment point location: which input point the query results refers to?, Florian Prud'homme, 03/01/2018
