cgal-discuss - Re: [cgal-discuss] Segmentation Fault while running Polyhedron demo
  • To:
  • Subject: Re: [cgal-discuss] Segmentation Fault while running Polyhedron demo
  • Date: Fri, 2 Mar 2018 08:58:37 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
I did do two installations of Qt but neither was a Qt4 installation.
I ensured that QGL viewer was compiled with Qt 5.6.2.
I don't know how to check if demo is being built with Qt 5.6.2 or not.
Here is the output from ldd Polyhedron_3:
$ldd Polyhedron_3
linux-vdso.so.1 => (0x00007ffdd4d96000)
libCGAL_Qt5.so.11 => /usr/lib/x86_64-linux-gnu/libCGAL_Qt5.so.11
(0x00007fea100dc000)
libdemo_framework.so =>
/home/param/Libs/demos/demo/Polyhedron/libdemo_framework.so
(0x00007fea0fea6000)
libpoint_dialog.so =>
/home/param/Libs/demos/demo/Polyhedron/libpoint_dialog.so
(0x00007fea0fc9d000)
libQGLViewer-qt5.so.2 => /usr/local/lib/libQGLViewer-qt5.so.2
(0x00007fea0f9ec000)
libQt5OpenGL.so.5 => /home/param/anaconda3/lib/libQt5OpenGL.so.5
(0x00007fea0f795000)
libQt5Widgets.so.5 => /home/param/anaconda3/lib/libQt5Widgets.so.5
(0x00007fea0ef69000)
libQt5Gui.so.5 => /home/param/anaconda3/lib/libQt5Gui.so.5
(0x00007fea0e79d000)
libQt5Script.so.5 => /home/param/anaconda3/lib/libQt5Script.so.5
(0x00007fea0e311000)
libQt5Core.so.5 => /home/param/anaconda3/lib/libQt5Core.so.5
(0x00007fea0dbef000)
libstdc++.so.6 => /home/param/anaconda3/lib/libstdc++.so.6
(0x00007fea0d8b5000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fea0d5ac000)
libgcc_s.so.1 => /home/param/anaconda3/lib/libgcc_s.so.1
(0x00007fea0d39a000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fea0cfd0000)
libQt5Svg.so.5 => /home/param/anaconda3/lib/libQt5Svg.so.5
(0x00007fea0cd7d000)
libGL.so.1 => /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
(0x00007fea0cb0a000)
libgl_splat.so =>
/home/param/Libs/demos/demo/Polyhedron/libgl_splat.so
(0x00007fea0c8fe000)
libGLU.so.1 => /usr/lib/x86_64-linux-gnu/libGLU.so.1
(0x00007fea0c68f000)
libQt5Xml.so.5 => /home/param/anaconda3/lib/libQt5Xml.so.5
(0x00007fea0c452000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0
(0x00007fea0c235000)
libpng16.so.16 => /home/param/anaconda3/lib/./libpng16.so.16
(0x00007fea0bffe000)
libz.so.1 => /home/param/anaconda3/lib/./libz.so.1
(0x00007fea0bde7000)
libicui18n.so.58 => /home/param/anaconda3/lib/./libicui18n.so.58
(0x00007fea0b972000)
libicuuc.so.58 => /home/param/anaconda3/lib/./libicuuc.so.58
(0x00007fea0b5c4000)
libicudata.so.58 => /home/param/anaconda3/lib/./libicudata.so.58
(0x00007fea09ac4000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fea098c0000)
libgthread-2.0.so.0 => /home/param/anaconda3/lib/./libgthread-2.0.so.0
(0x00007fea096be000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fea094b6000)
libglib-2.0.so.0 => /home/param/anaconda3/lib/./libglib-2.0.so.0
(0x00007fea091a3000)
/lib64/ld-linux-x86-64.so.2 (0x00007fea10316000)
libexpat.so.1 => /home/param/anaconda3/lib/libexpat.so.1
(0x00007fea08f70000)
libxcb-dri3.so.0 => /home/param/anaconda3/lib/libxcb-dri3.so.0
(0x00007fea08d6d000)
libxcb-present.so.0 => /home/param/anaconda3/lib/libxcb-present.so.0
(0x00007fea08b6a000)
libxcb-sync.so.1 => /home/param/anaconda3/lib/libxcb-sync.so.1
(0x00007fea08963000)
libxshmfence.so.1 => /usr/lib/x86_64-linux-gnu/libxshmfence.so.1
(0x00007fea08760000)
libglapi.so.0 => /usr/lib/x86_64-linux-gnu/libglapi.so.0
(0x00007fea08530000)
libXext.so.6 => /usr/lib/x86_64-linux-gnu/libXext.so.6
(0x00007fea0831e000)
libXdamage.so.1 => /usr/lib/x86_64-linux-gnu/libXdamage.so.1
(0x00007fea0811b000)
libXfixes.so.3 => /usr/lib/x86_64-linux-gnu/libXfixes.so.3
(0x00007fea07f15000)
libX11-xcb.so.1 => /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1
(0x00007fea07d13000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6
(0x00007fea079d9000)
libxcb-glx.so.0 => /home/param/anaconda3/lib/libxcb-glx.so.0
(0x00007fea077bd000)
libxcb-dri2.so.0 => /home/param/anaconda3/lib/libxcb-dri2.so.0
(0x00007fea075b8000)
libxcb.so.1 => /home/param/anaconda3/lib/libxcb.so.1
(0x00007fea0738f000)
libXxf86vm.so.1 => /usr/lib/x86_64-linux-gnu/libXxf86vm.so.1
(0x00007fea07189000)
libdrm.so.2 => /usr/lib/x86_64-linux-gnu/libdrm.so.2
(0x00007fea06f78000)
libpcre.so.1 => /home/param/anaconda3/lib/././libpcre.so.1
(0x00007fea06d33000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6
(0x00007fea06b2f000)
