- To: "" <>
- Subject: [cgal-discuss] Create Surface_Mesh from Alpha_Shape
- Date: Mon, 5 Mar 2018 12:04:19 +0000
- Accept-language: de-DE, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
Hi,
one more – hopefully simple to answer – question:
Having an alpha shape object (CGAL::Alpha_shape_3) in hand, how to create a Surface_Mesh from the alpha shape?
I’m still searching on my own in the docs, but hope to find a faster answer here on the list.
Kind regards Torge CENIT AG, Industriestrasse 52-54, 70565 Stuttgart, Tel.: +49 711 7825-30, Fax: +49 711 7825-4000, Internet: www.cenit.com Geschaeftsstellen: Berlin, Frankfurt, Hamburg, Hannover, Muenchen, Oelsnitz, Ratingen, Saarbruecken Vorstandsmitglieder: Kurt Bengel, Matthias Schmidt Aufsichtsratsmitglieder: Andreas Schmidt (Vorsitzender des Aufsichtsrats), Hubert Leypoldt, Andreas Karrer Bankverbindungen: Deutsche Bank (BLZ 600 700 70) Kto. 1661 040 IBAN : DE85 6007 0070 0166 1040 00 SWIFT-CODE : DEUTDESS, Commerzbank (BLZ 600 400 71) Kto. 532 015 500 IBAN : DE83 6004 0071 0532 0155 00 SWIFT-Code : COBADEFF600, Registergericht: Amtsgericht Stuttgart Handelsregister: HRB Nr. 19117 Umsatzsteuer: ID-Nr. DE 147 862 777 |
- [cgal-discuss] Create Surface_Mesh from Alpha_Shape, Riedel, Torge, 03/05/2018
- Re: [cgal-discuss] Create Surface_Mesh from Alpha_Shape, nolvis, 03/06/2018
