cgal-discuss - [cgal-discuss] Normal Estimate Example
  • To:
  • Subject: [cgal-discuss] Normal Estimate Example
  • Date: Mon, 12 Mar 2018 02:19:30 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi,
I am testing the normal_estimation example on a 124915192 points point
cloud.
jet_fitting with k=34 finished smoothly,
but after that when attempting to run MST to orient the normals with K=34 (I
tried default18, same thing happens),
the algorithm eats all 64GB main memory and used up all 16GB swap space (in
ubuntu).
I am wondering if it is caused by storing a too big minimum spanning tree in
main memory?
Would further lower down the number of K helps? but would that trade off the
quality of the result?
Any advise?
Thank you very much.
William
