cgal-discuss - Re: [cgal-discuss] Taking bounds, equality and transforms of Bezier curves?
  • To:
  • Subject: Re: [cgal-discuss] Taking bounds, equality and transforms of Bezier curves?
  • Date: Sun, 18 Mar 2018 22:40:20 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi Stu,
First, I'm glad that you are using it and finding out all kind of missing features.
I can confirm that non of the operations you mention are supported.
The operations you mention could definitely be implemented within the traits class.
However, the traits class models certain concepts, and non of the concepts that are modeled require any one of  these operations.
This is, naturally, not a reason not to implement them, but an explanation why we never bothered with any of them.
In other words, if we implement an operation in one traits class, we would implement it in all (or at least several).
BW, I'm currently implementing a generic operation that lexicographically compares 2 curves.
It is generic (applicable to all traits) in the sense that it is implemented in terms of other existing operations.
This way the implementation is more complex (see algorithm below) and gets even more complex when 2D arrangements embedded on non-planar surfaces are taken in account, but more is gained.
Input: C1, C2, intersections = empty
Compare the left-most point.
If not equal return the comparison result.
Otherwise (the left-most points are equal)
  Compare to the right of the point.
  Otherwise (they overlap)
    If intersection is empty, compute the intersections
    Remove the first overlapping section from c1, c2, and intersections.
    If intersections is empty
      Compare the right-most point and return the result
    call recursively with c1, c2, and intersections, and return the result.
Efi
On 17 March 2018 at 23:14, stu002 <> wrote:
Hi,
I'm working with cubic Bezier curves as defined in
CGAL::Arr_Bezier_curve_traits_2, the Curve_2 class.
Can I confirm there's no equality operator for these curves?  (I know I can
test the equality of the four control points myself but this seems like
functionality that belongs in the class).
Can I confirm there's no bounding box function for these curves? (I know I
can get a non-minimal AABB from the bounding polygon, but a minimal AABB is
trickier and it seems like functionality that belongs in the class. It looks
like the implementation classes have some kind of bounds stored too?).
Can I confirm there's no affine transform function for these curves? (I know
I can transform the four control points myself but this seems like
Thanks,
Stu
