- To:
- Subject: Re: [cgal-discuss] CGAL GUI
- Date: Tue, 3 Apr 2018 10:00:14 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hello,
Note that CGAL is a library that is not intended to offer end-user software. Apart from that, the GUI you see on this video is the Polyhedron demo which we commonly use to test and present our algorithms.
You can download a compiled version for windows from the manual: https://cgal.geometryfactory.com/CGAL/doc/master/Manual/packages.html#PkgClassificationSummary
(See "Windows Demo" + "Common Demo Dlls" on the right column.)
You can also compile it from the sources: https://github.com/CGAL/cgal/tree/master/Polyhedron/demo/Polyhedron
Best regards,
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
Le 03/04/2018 à 09:55, iampriyanshi a écrit :
Is there any GUI available for CGAL.
https://www.youtube.com/watch?v=luDHXaT9PjY
In the above video which interface is used, any idea?
- [cgal-discuss] CGAL GUI, iampriyanshi, 04/03/2018
- Re: [cgal-discuss] CGAL GUI, Simon Giraudot, 04/03/2018
- Re: [cgal-discuss] CGAL GUI, Laurent Rineau (CGAL/GeometryFactory), 04/03/2018
- Re: [cgal-discuss] CGAL GUI, Biswajit Biswas, 04/03/2018
