- To:
- Subject: Re: [cgal-discuss] visulization in cgal using qt
- Date: Tue, 17 Apr 2018 08:20:50 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
For 2D you have a whole chapter on visualization
https://doc.cgal.org/latest/GraphicsView/index.html#Chapter_CGAL_and_the_Qt_Graphics_View_Framework
For 3D there is the CGAL/demo/Polyhedron, but the internals
are not documented.
Best,
Andreas
On 4/16/2018 9:13 PM, hend helal wrote:
hii, i am new to cgal , and i want know how to visualize in cgal ,
there isn't any documentation of how to use the qt with cgal,
so is there any piece of code which describes using the qt with cgal in
order to visualize??
thanks in advance
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] visulization in cgal using qt, hend helal, 04/16/2018
- Re: [cgal-discuss] visulization in cgal using qt, Andreas Fabri, 04/17/2018
- Re: [cgal-discuss] visulization in cgal using qt, Hend Helal, 04/17/2018
