cgal-discuss - [cgal-discuss] Surface_mesh_parameterization didn't keep face information
  • To:
  • Subject: [cgal-discuss] Surface_mesh_parameterization didn't keep face information
  • Date: Thu, 19 Apr 2018 17:37:24 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
I test several examples by using example mesh. The result is good. But when I
open the mesh file, I found the face in the mesh between input and result is
very different.
For example,
Input:
First three lines of face information.
3 170 169 218
3 304 259 871
3 299 298 8
Result:
3 921 914 901
3 901 914 885
3 883 885 914
What I want is to change the face of the result as same as the input.
How can I deal with it?
Thank you very much.
