cgal-discuss - Re: [cgal-discuss] new to cgal
  • To:
  • Subject: Re: [cgal-discuss] new to cgal
  • Date: Mon, 16 Apr 2018 18:58:19 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Le Saturday, April 14, 2018 3:58:56 PM CEST hend helal a ?crit :
> hii i am trying to use the cgal library,but i have some errors
> first when generating the solution file in CMAKE , i get this error
> CMake Error in src/CGAL_Core/CMakeLists.txt:
> Target "CGAL_Core" INTERFACE_INCLUDE_DIRECTORIES property contains path:
> "C:/local/CGAL-4.12-beta2/auxiliary/gmp/include"
> which is prefixed in the source directory.
Hi,
We confirm the bug, and we will soon propose a fix¹.
Inbetween, CGAL version 4.11.1 should be fine for you, because the bug was
only introduced recently, in CGAL-4.12-beta1.
¹) The work in progress is in that pull-request named "Fix CMake scripts of
4.12-beta2 #3021":
https://github.com/CGAL/cgal/pull/3021
Laurent Rineau, PhD
  • [cgal-discuss] new to cgal, hend helal, 04/14/2018
    • Re: [cgal-discuss] new to cgal, Laurent Rineau (CGAL/GeometryFactory), 04/24/2018
