cgal-discuss - Re: [cgal-discuss] compile error
  • To:
  • Subject: Re: [cgal-discuss] compile error
  • Date: Thu, 3 May 2018 11:50:11 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
This is not the correct approach. Please use the solution that was
provided to you back then.
On 02/05/2018 21:59, Florian Prud'homme wrote:
> Hello ,
> I remember I have a problem a bit similar 6 months ago . I created a new
> file for this (in order to make it work with "data info" and "constrained"
> triangulation) :
>> * Delaunay_mesh_vertex_base_with_info_2.h
>> * Created on: Nov 23, 2017
>> * Author: florian
>> #ifndef DELAUNAY_MESH_VERTEX_BASE_WITH_INFO_2_H_
>> #define DELAUNAY_MESH_VERTEX_BASE_WITH_INFO_2_H_
>> #include <CGAL/Triangulation_vertex_base_2.h>
>> namespace CGAL {
>> template<typename Info_, typename GT, typename Vb =
>> Triangulation_vertex_base_2&lt;GT> >
>> class Delaunay_mesh_vertex_base_with_info_2: public Vb {
>> Info_ _info;
>> public:
>> typedef typename GT::FT FT;
>> typedef typename Vb::Face_handle Face_handle;
>> typedef typename Vb::Point Point;
>> typedef Info_ Info;
>> template<typename TDS2>
>> struct Rebind_TDS {
>> typedef typename Vb::template Rebind_TDS<TDS2>::Other Vb2;
>> typedef Delaunay_mesh_vertex_base_with_info_2<Info, GT, Vb2>
> Other;
>> protected:
>> FT sizing_info_;
>> public:
>> Delaunay_mesh_vertex_base_with_info_2() :
>> Vb(), sizing_info_(0.) {
>> Delaunay_mesh_vertex_base_with_info_2(const Point & p) :
>> Vb(p), sizing_info_(0.) {
>> Delaunay_mesh_vertex_base_with_info_2(const Point & p, Face_handle c)
>> Vb(p, c), sizing_info_(0.) {
>> Delaunay_mesh_vertex_base_with_info_2(Face_handle c) :
>> Vb(c), sizing_info_(0.) {
>> void set_sizing_info(const FT& s) {
>> sizing_info_ = s;
>> const FT& sizing_info() const {
>> return sizing_info_;
>> const Info& info() const {
>> return _info;
>> Info& info() {
>> return _info;
>> } // namespace CGAL
>> #endif /* DELAUNAY_MESH_VERTEX_BASE_WITH_INFO_2_H_ */
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
