- To:
- Subject: Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements
- Date: Thu, 03 May 2018 15:37:22 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
I am really having hard time switching from 4.4 to 4.12. Seems like arrangement crash if I don’t use exact construction but constrained Delaunay mesh does not compile with exact construction
The assertion that causes the error has been there for ever. It is active only in debug mode. It's possible that it has never worked in debug mode and still works in release mode. In any case I suggest that you switch to using an exact construction kernel, cause even if it has been working so far, the failure is around the corner regardless of the assertion.It worked for many years for all the problems I have tried, but I switch to 4.12 now it breaksWhen you use inexact construction, your program may work on some instances and may fail on other.We do not guarantee anything.____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/On 25 April 2018 at 18:49, Dinesh Shetty <> wrote:Well my version with 4.4 worksChange the first line to:This could have never worked.You are using inexact construction.
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;____ _ ____ _
_/On 24 April 2018 at 22:07, Dinesh Shetty <> wrote:typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;typedef Kernel::FT Number_type;typedef CGAL::Arr_segment_traits_2<Kernel> Traits;typedef Traits::Point_2 Point;typedef Traits::X_monotone_curve_2 Segment;typedef CGAL::Arrangement_2<Traits> Arrangement;typedef Arrangement::Vertex_handle Vertex_handle;typedef Arrangement::Halfedge_handle Halfedge_handle;typedef Arrangement::Face_handle Face_handle;typedef Arrangement::Vertex_const_handle Vertex_const_handle;typedef Arrangement::Halfedge_const_handle Halfedge_const_handle;typedef CGAL::Arr_consolidated_curve_data_traits_2<Traits, int>Data_traits;typedef Data_traits::Curve_2 Numbered_segment;typedef CGAL::Arrangement_2<Data_traits> Numbered_arr;Numbered_arr arr;insert(arr, Numbered_segment(Segment(Point(1.6831200000000E+02,-1.3992000000000E+01), Point( 1.2253100000000E+02, -2.0889000000000E+01)), 6));insert(arr, Numbered_segment(Segment(Point(1.6490200000000E+02, 1.0314000000000E+01), Point( 1.0342400000000E+02, 4.2850000000000E+00)), 11));insert(arr, Numbered_segment(Segment(Point(1.7217000000000E+02,-3.2611000000000E+01), Point( 9.9756000000000E+01, -4.3728000000000E+01)), 16));insert(arr, Numbered_segment(Segment(Point(1.4197300000000E+02, 5.4490000000000E+00), Point( 1.4887000000000E+02, -4.0331000000000E+01)), 51));std::stringstream ss;Numbered_arr::Vertex_const_iterator vit;for (vit = arr.vertices_begin(); vit != arr.vertices_end(); ++vit){std::map<int, int> Frequency;Numbered_arr::Halfedge_around_vertex_const_circulator eit, first;eit = first = vit->incident_halfedges();do{++Frequency[eit->curve().data().front()];} while (++eit != first);ss << "@ ( " << vit->point() << ")" <<std::endl;for(auto & itr : Frequency){ss<<itr.first<<" apprears "<<itr.second<<"\n";}}Numbered_arr::Edge_const_iterator eit;std::vector<int> Pid;for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit){Data_traits::Data_container::const_iterator it;if(eit->curve().data().size()> 1){Pid.clear();Pid.reserve(eit->curve().data().size());for (it = eit->curve().data().begin(); it != eit->curve().data().end(); ++it){Pid.push_back(*it);}ss<<"Overlap detected : ";for(auto & itr : Pid)ss<<itr<<" ";ss<<"\n";}}ss << arr.number_of_edges() << " edges:" << std::endl;for (eit = arr.edges_begin(); eit != arr.edges_end(); ++eit)ss << "[" << eit->curve() << "]" << std::endl;On Tue, Apr 24, 2018 at 12:33 PM, Efi Fogel <> wrote:Please provide a test case that reproduces the problem.____ _ ____ _
_/On 24 April 2018 at 17:32, Dinesh Shetty <> wrote:When I switched to CGAL 4.12-beta2 from CGAL-4.4, I get following exception thrownException: CGAL ERROR: precondition violation!Expr: (m_traits.compare_y_at_x_2_object()(p, cv) == EQUAL) && compare_xy(cv.left(), p) == SMALLER && compare_xy(cv.right(), p) == LARGERFile: D:\PE\PE_Software\3rdParty\CGAL\CGAL-4.12-beta2\include\CGAL/Arr_segment_traits_2.hLine: 714Any help appreciated..On stackExchange
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Dinesh Shetty, 05/03/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Sebastien Loriot (GeometryFactory), 05/03/2018
- Re: [cgal-discuss] CGAL fails with insertion operation in 2D arrangements, Efi Fogel, 05/03/2018
