- To:
- Subject: Re: [cgal-discuss] Functions of 2D and 3D Geometric Kernel
- Date: Wed, 16 May 2018 12:25:10 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hello, You can read about concepts and models are here: https://doc.cgal.org/latest/Manual/tutorial_hello_world.html#intro_concept. In your case, Compute_squared_radius_smallest_orthogonal_circle_2 is indeed a model of the functor concept ComputeSquaredRadiusSmallestOrthogonalCircle__2, and it can be used as follows: typedef CGAL::Exact_predicates_exact_constructions_kernel EPECK; typedef EPECK::FT FT; typedef EPECK::Weighted_point_2 Weighted_point; typedef EPECK::Compute_squared_radius_smallest_orthogonal_circle_2 Smallest_circle; EPECK kernel; Weighted_point wp1, wp2; Smallest_circle sc = kernel.compute_squared_radius_smallest_orthogonal_circle_2_object(); FT result = sc(wp1, wp2); In general, kernel objects and functors are defined because there is a use for it, so if you can search the source code of CGAL to find out how they are used in practice. On 16/05/2018 11:51, Kathi wrote:
Hello, I don't manage to use the member functions of a 2D/3D geometric kernel as listed on https://doc.cgal.org/latest/Kernel_23/classKernel.html . Maybe the problem arises from the fact that I do not fully understand what a concept, model etc is and especially how to make use of them in practice. To make my problem specific: I am working with the Exact_predicates_exact_constructions_kernel and want to (for example) compute the squared radius of the smallest orthogonal circle of two weighted points in 2D. In the reference manual I found: Compute_squared_radius_smallest_orthogonal_circle_2, a model of Kernel::ComputeSquaredRadiusSmallestOrthogonalCircle_2. But I was not able to use it. I tried CGAL::, CGAL::Exact_predicates_exact_constructions_kernel::, etc but the function is never found ("not a member of ..."). It would be very helpful if anybody could provide a minimum working example which makes use of the function. Thanks for your help, Kathi -- Sent from: http://cgal-discuss.949826.n4.nabble.com/ |
- [cgal-discuss] Functions of 2D and 3D Geometric Kernel, Kathi, 05/16/2018
- Re: [cgal-discuss] Functions of 2D and 3D Geometric Kernel, Mael Rouxel-Labbé, 05/16/2018
