cgal-discuss - Re: [cgal-discuss] Reliable way to offset a mesh?
  • To:
  • Subject: Re: [cgal-discuss] Reliable way to offset a mesh?
  • Date: Wed, 23 May 2018 09:28:22 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
OK so I just rewrote the program to use Mesh_3. One problem I
encountered is that I want to restrict the output mesh to be manifold,
but the named parameters doesn't seem to work. It told me:
/home/riaqn/codes/cxx/offset.cxx:65:102: error: ‘manifold’ was not
declared in this scope
base<T>::Meshing::C3t3 c3t3 = CGAL::make_mesh_3<typename
base<T>::Meshing::C3t3>(domain, criteria,
manifold=params::manifold());
it seems that there isn't such a named parameter in make_mesh_3's signature?
Best,
Zesen
On Wed, May 23, 2018 at 2:57 AM, Sebastien Loriot (GeometryFactory)
wrote:
> On 05/22/2018 08:33 PM, Zesen Qian wrote:
>> Hi Sebastien,
>> Thanks for this. I wrote the program myself and I'm using surface_mesh
>> instead of mesh_3. Question: Why will Mesh_3 be faster? From what I
>> understand this will not only generate facets but also cells inside
>> the shape? How will that accelerate the process?
> Mesh_3 code has been updated to take advantage of threads so it will be
> faster. Moreover, the code of Surface_mesh has not been updated for some
> time now because we are planning to replace it with the implementation of
> Mesh_3. If you put no constraints on the tetrahedra, only the constraints on
> surface facets will make the mesh work more.
> Sebastien.
>> And in particular, if I'm not interested in the cells, how should I
>> set the parameters concerning it? i.e., cell_radius_edge_ratio and
>> cell_size.
>> Best,
>> Zesen
>> On Tue, May 22, 2018 at 2:25 PM, Sebastien Loriot (GeometryFactory)
>> wrote:
>>> Note that this PR : https://github.com/CGAL/cgal/pull/3043
>>> will bring some noticeable speed up as well as parallel mesh algorithm.
>>> Best,
>>> Sebastien.
>>> On 05/22/2018 07:18 PM, Zesen Qian wrote:
>>>> Hi Sebastien,
>>>> Sorry for keep spamming your inbox - but I found how to sample areas
>>>> differently based on variety. For future reference, the parameter
>>>> distance_bound constrols the max distance from every generated facet
>>>> to the surface. So when the same value applies to different areas, the
>>>> areas with more details will get sampled more.
>>>> Thank you so much for the help!
>>>> Best,
>>>> Zesen
>>>> On Tue, May 22, 2018 at 11:11 AM, Zesen Qian
>>>> wrote:
>>>>> Hi Sebastien,
>>>>> I think I was mistaken - I tried it again and it seems that I don't
>>>>> have to do too much about the angle_bound - adjusting other parameters
>>>>> would suffice to give a decent result.
>>>>> However, it is indeed slow. One feature of my mesh is that it donsn't
>>>>> have to be evenly sampled - some areas require more details than
>>>>> others. Can I do some trick so that those area receive extra
>>>>> sampling, while other more monotone area get less, so I can save some
>>>>> processing time?
>>>>> Best,
>>>>> Zesen
>>>>> On Tue, May 22, 2018 at 10:26 AM, Zesen Qian
>>>>> wrote:
>>>>>> Hi Sebastien,
>>>>>> Thanks for this. I don't know if that's a similiar thing, but I tried
>>>>>> https://doc.cgal.org/latest/Surface_mesher/
>>>>>> by a distance function(with AABB_tree and side_of_triangle). Seen from
>>>>>> the source code of the plugin, it's very similar.
>>>>>> To get a decent result it's quite slow. If I set the angular bound to
>>>>>> 90 degree(more than 30), the algorithm is not garanteed to
>>>>>> terminate(and indeed in my case). My mesh has some very thin layers
>>>>>> that's easy to be ignored by meshing, so I don't expect this method
>>>>>> to work.
>>>>>> What I'm now trying is simply using the "solidify" modifier in
>>>>>> Blender, and fix the potential self-intersections using refining and
>>>>>> outer-hull operation, and then use boolean operation with the original
>>>>>> mesh to get a offseted mesh. I'm using libigl to do these tasks.
>>>>>> Best,
>>>>>> Zesen
>>>>>> On Tue, May 22, 2018 at 9:59 AM, Sebastien Loriot (GeometryFactory)
>>>>>> wrote:
>>>>>>> There is indeed nothing official in CGAL. However, in the Polyhedron
>>>>>>> demo we wrote a small plugin that is meshing the distance function to
>>>>>>> a
>>>>>>> mesh
>>>>>>> and the output is by construction guaranteed to be free from
>>>>>>> self-intersections. However sharp features are not correctly meshed
>>>>>>> if
>>>>>>> not protected.
>>>>>>> Go into 3D Surface Mesh Generation -> Offset meshing once having
>>>>>>> loaded
>>>>>>> a polyhedron.
>>>>>>> Source code is here:
>>>>>>> https://github.com/CGAL/cgal/blob/releases/CGAL-4.12-branch/Polyhedron/demo/Polyhedron/Plugins/Surface_mesh/Offset_meshing_plugin.cpp
>>>>>>> HTH,
>>>>>>> Sebastien.
>>>>>>> On 05/17/2018 07:44 PM, Zesen Qian wrote:
>>>>>>>> Hi list,
>>>>>>>> I have a triangulated, closed mesh which is free of any
>>>>>>>> degeneracies.
>>>>>>>> Is there any reliable way to offset this mesh? By reliable I mean
>>>>>>>> the
>>>>>>>> result mesh should be free of any degeneracies.
>>>>>>>> I searched on Internet and there is simply not an library/program
>>>>>>>> available that can do this. I guess CGAL isn't capable of this
>>>>>>>> either,
>>>>>>>> but I believe people on this list should be familiar with this topic
>>>>>>>> and maybe offer some comments.
>>>>>>>> Thank you.
>>>>>>>> Best,
>>>>>>>> Zesen
>>>>>>> You are currently subscribed to cgal-discuss.
>>>>>>> To unsubscribe or access the archives, go to
>>>>>>> https://sympa.inria.fr/sympa/info/cgal-discuss
