cgal-discuss - [cgal-discuss] Segfault when generating a mesh from an implicit surface
  • To: <>
  • Subject: [cgal-discuss] Segfault when generating a mesh from an implicit surface
  • Date: Sat, 26 May 2018 21:01:07 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi,
I wanted to compare different methods to turn implicit surfaces into a mesh.
In the attached code I compared CGAL::make_mesh_3 with CGAL::make_surface_mesh.
I can deactivate the code using either of these functions using the defines at the top of the file.
If  I activate only one of these functions, the executable generates the meshes.
So far all is good.
If I activate both functions to do the conversion, the executable segfaults:
void impl_mesh_via_all(double) 4
void impl_mesh_via_make_surface_mesh(double) 4
    impl
    convert
    save
void impl_mesh_via_make_mesh_3(double) 4
    impl
    convert
Segmentation fault (core dumped)
I do not understand this, since both functions work if I only use one in the executable.
Can anyone tell me what the reason for this is?
Best Regards,
Raphael
Karlsruhe Institute of Technology (KIT)
Institute for Anthropomatics and Robotics (IAR)
High Performance Humanoid Technologies (H2T)
Raphael Grimm (M.Sc.)
Research Scientist
Adenauerring 2
Building 50.20, Room 334
76131 Karlsruhe, Germany
Phone: +49 721 608-47133
Fax: +49 721 608-48270
Email:
Web: http://h2t.anthropomatik.kit.edu/
KIT - The Research University in the Helmholtz Association
#define build_make_mesh_3
#define build_make_surface_mesh
#include <fstream>
#include <boost/current_function.hpp>
#ifdef build_make_mesh_3
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/Implicit_mesh_domain_3.h>
#include <CGAL/make_mesh_3.h>
#include <CGAL/IO/facets_in_complex_3_to_triangle_mesh.h>
#endif
#ifdef build_make_surface_mesh
#include <CGAL/Surface_mesh_default_triangulation_3.h>
#include <CGAL/Complex_2_in_triangulation_3.h>
#include <CGAL/make_surface_mesh.h>
#include <CGAL/Implicit_surface_3.h>
#include <CGAL/IO/facets_in_complex_2_to_triangle_mesh.h>
#endif
#include <CGAL/Polyhedron_3.h>
using Poly = CGAL::Polyhedron_3<CGAL::Epick>;
using ResultT = Poly;
using Sphere_3  = typename CGAL::Epick::Sphere_3;
using Point_3   = typename CGAL::Epick::Point_3 ;
using Function = double (*)(const Point_3&);
double sphere_function (const Point_3& p)
    return CGAL::squared_distance(p, Point_3(CGAL::ORIGIN))-1;
// //////////////////////////////// make_mesh_3 /////////////////////////////// //
void impl_mesh_via_make_mesh_3(double r)
    std::cout << BOOST_CURRENT_FUNCTION << " " << r << std::endl;
    using impl_mesh = CGAL::Implicit_mesh_domain_3<Function, CGAL::Epick>;
    using Traits = CGAL::Mesh_triangulation_3<impl_mesh,CGAL::Default, CGAL::Sequential_tag>::type;
    using C3t3 = CGAL::Mesh_complex_3_in_triangulation_3<Traits>;
    std::cout << "    impl" << std::endl;
    impl_mesh impl(sphere_function, Sphere_3(CGAL::ORIGIN, r));
    std::cout << "    convert" << std::endl;
    CGAL::Mesh_criteria_3<Traits> criteria(
        CGAL::parameters::facet_angle            = 30,
        CGAL::parameters::facet_size             = 0.1,
        CGAL::parameters::facet_distance         = 0.025,
        CGAL::parameters::cell_radius_edge_ratio = 2,
        CGAL::parameters::cell_size              = 0.1
    C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(impl, criteria);
    std::cout << "    save" << std::endl;
    ResultT result;
    CGAL::facets_in_complex_3_to_triangle_mesh(c3t3, result);
    const std::string file = "sphere_impl_mesh_via_make_mesh_3_r_" + std::to_string(r) + ".off";
    std::ofstream{file} << result;
#endif
// ///////////////////////////// make_surface_mesh //////////////////////////// //
void impl_mesh_via_make_surface_mesh(double r)
    using Traits    = typename CGAL::Surface_mesher::Surface_mesh_default_triangulation_3_generator<CGAL::Epick>::Type;
    using C2t3      = CGAL::Complex_2_in_triangulation_3<Traits>;
    using impl_surf = CGAL::Implicit_surface_3<typename Traits::Geom_traits, Function>;
    impl_surf impl(sphere_function, CGAL::Epick::Sphere_3(CGAL::ORIGIN, r));
    Traits tr;
    C2t3 c2t3 (tr);
    CGAL::Surface_mesh_default_criteria_3<Traits> criteria(30, 0.1, 0.1);
    CGAL::make_surface_mesh(c2t3, impl, criteria, CGAL::Non_manifold_tag());
    ResultT result;
    CGAL::facets_in_complex_2_to_triangle_mesh(c2t3, result);
    const std::string file = "sphere_impl_mesh_via_make_surface_mesh_r_" + std::to_string(r) + ".off";
#endif
// /////////////////////////////////// exec /////////////////////////////////// //
void impl_mesh_via_all(double r)
    impl_mesh_via_make_surface_mesh(r);
#endif
    impl_mesh_via_make_mesh_3(r);
#endif
int main()
    impl_mesh_via_all(4);
    impl_mesh_via_all(8);
    impl_mesh_via_all(16);
    impl_mesh_via_all(32);
    impl_mesh_via_all(64);
    impl_mesh_via_all(128);
    impl_mesh_via_all(256);
    impl_mesh_via_all(512);
    impl_mesh_via_all(1024);
    impl_mesh_via_all(2048);
    return 0;
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
