cgal-discuss - Re: [cgal-discuss] Can We use CGAL/Surface_mesh.h methods for not valid mesh?
  • To:
  • Subject: Re: [cgal-discuss] Can We use CGAL/Surface_mesh.h methods for not valid mesh?
  • Date: Wed, 6 Jun 2018 17:35:19 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:EZ31phOhCHtCuIMlxDQl6mtUPXoX/o7sNwtQ0KIMzox0Iv79rarrMEGX3/hxlliBBdydt6oZzbKO+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2aFLduGC94iAPERvjKwV1Ov71GonPhMiryuy+4ZLebxlIiTanfb9+MAi9oBnMuMURnYZsMLs6xAHTontPdeRWxGdoKkyWkh3h+Mq+/4Nt/jpJtf45+MFOTav1f6IjTbxFFzsmKHw65NfqtRbYUwSC4GYXX3gMnRpJBwjF6wz6Xov0vyDnuOdxxDWWMMvrRr0yRD+s7bpkSAXwhSgFOT438G/ZhM9tgqxFvB2svAZwz5LObYyPKPZyYqHQcNUHTmRBRMZRUClBD5unb4QRFeoBMudYr47grFQStxS+ABGsBOTywTJPmH/5x7E10+UnEQHJ0gwgGMgOsHPPodX6MacdS+G1zK3SwTrfaPNW3C7w5Y7VeR4vpvGMWKh/ccvXyUQ3EQPKlE6fppfhPzyLzOgCr2+b7+94WeKujW4nsQBxrSK1yscikInFnp4ayl/e+iV92oo1Ise4SEF9bNW5E5VQrzmXOol5T884Xm1kpiY3xqcFtJKlZiQHyZYqyhjCYPKdaYeI+AjsVOOJLDd4mn1lfLW/ig638Ue6y+38UtC40VhPriZZi9XMuHEA2h7J5siITft9+Uih2TKR2AzJ9u5EJkU0mbLaK54n3LEwioIevEbMEyPshUn6kq+bel8n9+S28ejqY7frqoeZN4BuiwH+Nqoumta4AeQ9KgUOQXKU9vi91L3l8k35TrJKjucxkqTCv5DaIN4Upq+9AwNPzokj7BO/Ay+80NsEhXkHME5FeBWfgof1NFHBOvT4Ae6ijFStizdk2+3GPqb6ApjWNXjCkLLhfa5n5EJGyQozy8pf55NOBb0bLvLzQBy5idrDExVsMxCo2/21T5Jmx4YGUCSOBLWYOeXcqxiT9+c3Kq6NYoES/z3yIvxg6//1hmIiggwhevyi0pITLXy5Bf97OF6xYHz2g95HH31ZkBA5SbnxhUeNUDkbbH+3R6V0si8yA4OgAonEXIeFj7mI3SP9FZpTMDMVQmuQGGvlIt3XE8wHbzifd5c4w240EIO5Qopk7imA8Qrzyr5pNO3Ro3RKupfq1dwz7OrWx0hrqW5ESv+F2mTIdFla23sSTmZvjq96qE15jFyE1Pog2qEKJZlo//pMFzwCG9vcwuh9UY2gXwvAepKWTQ7jTIv5Rz42Sd01zpkFZEMvQ9g=
Ok thank you!
On Wed, Jun 6, 2018 at 5:05 PM, Sebastien Loriot (GeometryFactory) <> wrote:
You can only store manifold meshes.
Sebastien.
On 06/06/2018 04:50 PM, sergio wrote:
Im try to implement diagnostic algorithms for not valid mesh(non-manifold
vertices, non-manifold edges, etc) I know that there are functions that let
me repair these errors. I don't want to repair it. What I want to only do it
is to Diagnostic a mesh with a particular error (Not repairĀ  it).
I try to use CGAL/Surface_mesh.h
https://doc.cgal.org/latest/Surface_mesh/index.html#title13
in order to iterate through all structure data and find these errors but it
does not work if the mesh has errors.
how i can iterate through haldedges, vertices, points of the invalid mesh in
order to find this errors? (Not repairing methods please)
For example: cube_e.off has non manifold vertex
cube_e.off
<http://cgal-discuss.949826.n4.nabble.com/file/t375958/cube_e.off>
if the file is process with this example it does not work:
https://doc.cgal.org/latest/Surface_mesh/Surface_mesh_2sm_kruskal_8cpp-example.html
