- To:
- Cc: Zesen Qian <>
- Subject: Re: [cgal-discuss] Question about Mesh_3
- Date: Wed, 06 Jun 2018 17:41:59 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Le Tuesday, June 5, 2018 7:47:50 PM CEST Zesen Qian a écrit :
> Hi list,
> I have several question about Mesh_3.
> 1. I'm generating isosurface by implicit function. It requires that
> the center of the sphere be inside of the mesh. The question is, given
> an arbitrary mesh, how can I find such a point?
Hi,
You talk at the same time about an implicit function and a mesh. What is
actually your input?
> 2. Due to the first problem(I guess), the mesher seems to be sampling
> a lot at a specific spot on the surface, making the mesh very dense at
> that spot. While the generated mesh is self-intersection free by
> construction, the exported .off is not(because of the precision
> issue). I have set the precision to 17-digits and it doesn't help. I
> guess one approach is to give a lower bound on the facet_size, but I
> coudln't find such a parameter. Another approach is to simplify the
> mesh, but I'm worried this might lose some details of the mesh.
That is probably related. The default initialization of the mesh is done by
shooting random ray around a point (and that point is the center of the
sphere by default). If that point is close to the iso-surface, then ray
shootings will produces initial points that are very close.
Laurent Rineau, PhD
- [cgal-discuss] Question about Mesh_3, Zesen Qian, 06/05/2018
- Re: [cgal-discuss] Question about Mesh_3, Laurent Rineau (CGAL/GeometryFactory), 06/06/2018
- Re: [cgal-discuss] Question about Mesh_3, Andreas Fabri, 06/06/2018
