cgal-discuss - [cgal-discuss] Bug with dD Triangulation stream operators?
  • To:
  • Subject: [cgal-discuss] Bug with dD Triangulation stream operators?
  • Date: Thu, 7 Jun 2018 19:06:36 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
I wrote a trivial program that initializes a dD triangulation, writes the
triangulation to a file using the given overloaded operator<<, and then
tries to read the file into the triangulation using operator>>.
I noticed that the operator<< works fine, but operator>> ends up giving a
long list of template substitution errors due to the line at
Triangulation_vertex.h:116 at "is >> v.point();". I think it might have to
do with the fact that v.point() in that line returns a const reference.
However, after I removed it, it still reports an error.
There does not seem to be any problem when I initialize the 3D or 2D
triangulation however.
Is this a small oversight in the dD triangulation? How can I circumvent it?
