cgal-discuss - Re: [cgal-discuss] Meshing implicit surfaces creates inside out meshes.
  • To:
  • Subject: Re: [cgal-discuss] Meshing implicit surfaces creates inside out meshes.
  • Date: Wed, 13 Jun 2018 17:28:39 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23:Gs5lURPFGoTN5LAzeDol6mtUPXoX/o7sNwtQ0KIMzox0Ivn7rarrMEGX3/hxlliBBdydt6oZzbKO+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2aFLduGC94iAPERvjKwV1Ov71GonPhMiryuy+4ZLebxlIiTanfb9+MAi9oBnMuMURnYZsMLs6xAHTontPdeRWxGdoKkyWkh3h+Mq+/4Nt/jpJtf45+MFOTav1f6IjTbxFFzsmKHw65NfqtRbYUwSC4GYXX3gMnRpJBwjF6wz6Xov0vyDnuOdxxDWWMMvrRr0yRD+s7bpkSAXwhSgFOT438G/ZhM9tgqxFvB2vqAdyw5LNYIyPKPZyYr/RcNEcSGFcXshRTStBAoakYoQMEeUBJvhXr4/grFUVrBuxHw+sD/7oxz5JmHD2xrM10+I7HQHf3QwvBdQOvW/brNXwLqgSUOS1wLPUwjXEavNbwDHw45XGfBAmpPGDR7NwcczJxEkuEQPFlFSQppb/MzObzOQBq3SU7+V6WuKrkWInrBtxoje3yscjlIbJgYcVxU7Y9SVjwIc1K8e3R1JnYd6jCptRtzuWOJdxQsMnRWxjpSU0yqUetJKlYCQHzI4ryh3fZvCdboSF5gzvWPyMLTp5gH9ofq+0iQyo/ki60OL8U9G50FZUoSpBldnBrnUN2AbS6siDU/d95kmh1SqW2wDd9+1JIEQ5mbDUK54mxb4wmZ4TvlrZEiDqn0X2ibeadkQi+ue29+TqeqvqqoOYOoNuiQzzMr4iltG7DOgmKAQCQmmW9OCk2L3m50L5QbFKjvMskqnetZDXPcUaqbCiAwBL1IYv8Q+/Dza839QehnQHI1dFdwiGj4jtIV3BPPf4DfKnj1S2jDhr3+zGPqHmApjVMnfDn63ufbJk50FByQoz1sxQ549PCrEaO//zQU/wtNnADhAjKQC0wuDnCM981owEQ26PDLWZY+vvt0SV7LcvP/WUf91S/y3sLuAsof/ol34w31EHOrK42IMeL3G+EPMhKEqQZT/gg8wKDHwR7TY5GeflgVnHXT9IbGupRIo94Cs6AcSoF9TtXIeo1Y6Mxyq9VqRXb2YOXkKBCnruMZyFUvEkZyebI8snmTsBA+vyA7Q93A2j4Vepg4FsKfDZr3VB5MDTkeNt7uiWrikcsDl9DsCTyWaIFjgmkWYBRjtw16d68xUklgWzlJNgivkdLuR9outTW15jZ5HZxu1+Tdv1X1CZJ4rbeBOdWtyjRAoJYJcxztsJORgvHtyjilXb0XLvDeZLxvqEA5s79q+a1H/0dZ5w
Thank you Laurent, it works perfectly.
On Tue, Jun 12, 2018 at 12:10 PM, Laurent Rineau
(CGAL/GeometryFactory)
wrote:
> Le Tuesday, June 12, 2018 4:45:08 PM CEST Zesen Qian a écrit :
>> Hi Sebastien,
>> Thank you for the comment. I actually encountered this problem as
>> well, and the method you suggested should solve it well. Only one
>> question remains, however: is there anyway to get a Surface_mesh from
>> c3t3 directly, besides calling export_surface_to_off() and then
>> reading it back?
> In CGAL-4.12, there is that function:
> void CGAL::facets_in_complex_3_to_triangle_mesh (const C3T3 &,
> TriangleMesh &);
> https://doc.cgal.org/latest/Mesh_3/group__PkgMesh__3Functions.html#ga68ca38989087644fb6b893eb566be9ea
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
