cgal-discuss - [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when i build my application in Release
  • To:
  • Subject: [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when i build my application in Release
  • Date: Wed, 4 Jul 2018 02:02:07 -0700 (MST)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
This is may application that i compile in windows in Release with the showed
CMakeList.txt and cgal_vtk_test.cpp files. When I try to repair this file:
Number intersection: 290
https://drive.google.com/file/d/1uqcbZqgtbiiXYjKnzzb5d-OXm4JAHqdx/view?usp=sharing
1. my application build in Release generate the following file:
Number intersections: 179
Add some visible holes and some deformations.
Repairing time:..................201.128 seconds.
https://drive.google.com/file/d/13Vfw0pP5Ymw0oo4RnfRjKTI_aTndb6P4/view?usp=sharing
2. my application compiled in Debug, it generate the following file:
Number intersections: 4
Repairing time:..................1072.96 seconds.
https://drive.google.com/file/d/1x1Z7qaNcnfGC8a24qzJI-DZEF3qqeLqq/view?usp=sharing
with warnings:
Expression : !"Returning no output. Filling hole with extra triangles is not
successful!"
File :
C:\dev\CGAL-4.12\include\CGAL/Polygon_mesh_processing/internal/Hole_filling/Triangulate_hole_polyline.h
Line : 1103
Explanation:
Refer to the bug-reporting instructions at
https://www.cgal.org/bug_report.html
The problem is that in debug build it takes around 17 min for reparacion and
in Release it only takes 3 minutes.
What's wrong?
CMakeList.txt
cmake_minimum_required(VERSION 2.8.4)
project( cgal_vtk_test )
# Find CGAL
find_package(CGAL REQUIRED COMPONENTS Core) # If the dependency is required,
use REQUIRED option - if it's not found CMake will issue an error
include( ${CGAL_USE_FILE} )
# Find VTK
find_package(VTK REQUIRED)
include(${VTK_USE_FILE})
# Setup your executable
#include_directories (BEFORE "include")
include( CGAL_CreateSingleSourceCGALProgram )
create_single_source_cgal_program( "cgal_vtk_test.cpp" ) # This will create
an executable target with name 'cgal_vtk_test'
# Add VTK link libraries to your executable target
target_link_libraries(cgal_vtk_test ${VTK_LIBRARIES})
#target_link_libraries(cgal_vtk_test)
cgal_vtk_test.cpp
#include <fstream>
#include <iomanip>
#include <ctime>
// CGAL
#include <limits>
#include <CGAL/Polygon_mesh_processing/repair.h>
#include <CGAL/Polygon_mesh_processing/internal/repair_extra.h>
#include <CGAL/Polygon_mesh_processing/corefinement.h>
#include <CGAL/Polygon_mesh_processing/polygon_soup_to_polygon_mesh.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/Surface_mesh/Surface_mesh.h>
#include <CGAL/IO/print_wavefront.h>
#include <CGAL/IO/OBJ_reader.h>
#include <CGAL/assertions.h>
#include <CGAL/IO/STL_reader.h>
#include <CGAL/IO/STL_writer.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef CGAL::Surface_mesh<Kernel::Point_3> Mesh;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
void addStringToFileName(std::string & fileName, const std::string & str)
size_t lastindex = fileName.find_last_of(".");
std::string name = fileName.substr(0, lastindex);
fileName = name + str;
bool repairOBJFile(std::string & fileName)
clock_t begin = clock();
std::cout << std::endl;
std::cout <<
<< std::endl;
std::cout << ". Repairing
<< std::endl;
std::cout <<
<< std::endl;
std::ifstream input(fileName);
if (!input)
std::cerr << "Cannot open file " << std::endl;
return false;
std::vector<Kernel::Point_3> points;
std::vector< std::vector<std::size_t> > polygons;
if (!CGAL::read_OBJ(input, points, polygons))
std::cerr << "Error parsing the OFF file " << std::endl;
return false;
//Mesh mesh;
Polyhedron mesh;
CGAL::Polygon_mesh_processing::orient_polygon_soup(points, polygons);
CGAL::Polygon_mesh_processing::polygon_soup_to_polygon_mesh(points,
polygons, mesh);
bool solved =
CGAL::Polygon_mesh_processing::remove_self_intersections(mesh);
if (!solved)
std::cout << "Some self-intersection could not be fixed" <<
std::endl;
//return false;
addStringToFileName(fileName, "_fixed.obj");
std::ofstream ofs(fileName);
CGAL::print_polyhedron_wavefront(ofs, mesh);
clock_t end = clock();
double elapsed_secs = double(end - begin) / CLOCKS_PER_SEC;
std::cout << "Repairing time:.................." << elapsed_secs << "
seconds."<< std::endl;
return true;
int main(int argc, char* argv[])
std::string fileName = argv[1];
repairOBJFile(fileName);
return 0;
  • [cgal-discuss] remove_self_intersections changes the mesh and the reparation is less when i build my application in Release, sergio, 07/04/2018
