Re: [cgal-discuss] CGAL warning: check violation! in CGAL::Polygon_mesh_processing::remove_self_intersections
- To:
- Subject: Re: [cgal-discuss] CGAL warning: check violation! in CGAL::Polygon_mesh_processing::remove_self_intersections
- Date: Wed, 4 Jul 2018 02:29:41 -0700 (MST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
You right. Let me add another discussion related to build my application in
release:
http://cgal-discuss.949826.n4.nabble.com/remove-self-intersections-changes-the-mesh-and-the-reparation-is-less-than-when-i-build-my-applicatig-tc4663643.html
Thanks you.
Sergio
- Re: [cgal-discuss] CGAL warning: check violation! in CGAL::Polygon_mesh_processing::remove_self_intersections, Sebastien Loriot (GeometryFactory), 07/02/2018
- Re: [cgal-discuss] CGAL warning: check violation! in CGAL::Polygon_mesh_processing::remove_self_intersections, sergio, 07/03/2018
- Re: [cgal-discuss] CGAL warning: check violation! in CGAL::Polygon_mesh_processing::remove_self_intersections, sergio, 07/04/2018
