cgal-discuss - [cgal-discuss] Sweep algorithm return intersecting segments
  • To:
  • Subject: [cgal-discuss] Sweep algorithm return intersecting segments
  • Date: Thu, 12 Jul 2018 03:14:59 -0700 (MST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=Pass
  • Ironport-phdr: 9a23:wPSB9hVHcUpxXm4Jff9TOe3BqQPV8LGtZVwlr6E/grcLSJyIuqrYYxCAt8tkgFKBZ4jH8fUM07OQ7/i+HzRYqb+681k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i764jEdAAjwOhRoLerpBIHSk9631+ev8JHPfglEnjWwba9zIRmssQndqtQdjJd/JKo21hbHuGZDdf5MxWNvK1KTnhL86dm18ZV+7SleuO8v+tBZX6nicKs2UbJXDDI9M2Ao/8LrrgXMTRGO5nQHTGoblAdDDhXf4xH7WpfxtTb6tvZ41SKHM8D6Uaw4VDK/5KptVRTmijoINyQh/W/ZisJ+kqFVrg+uqBNjzIDZe52VOfhicq/BYd8WWXRNU8BMXCJBGIO8aI4PAvIaMuZCtYb9pl0OrQC6BQmxH+PvyiJDi3jt0qIk1eQhFwHH0RcgH9IJqnTUttL1NL0JUe+r1qnI0zTDYO9I1jvn9YfHbAksrPeRVrx+dsrRzFMgFwLDjliIr4zqJSia2f8Js2eF9eZvSeWvi2s/pw5trTig3MMshpPOhoIPxVDJ8zhyzoUtJdCgVUJ2YMCoHIFOuyyaOYZ6WN4uTm9mtSogyLAKp5i2dzUQxps93R7QcfmHfpCI4h39UOaRJi91hHRqdb6lgRa961Ovxfb4VsaqylpFsi1FktzUunAM0Rzc9NSHR+Ng8kqgxzqDzR7f5+FKLEwuiKbWJZAszqQym5YNqUjDGzX5mETyjK+YbEUk/e2o5vz8bbr4oJ+cMY91hxr+MqQpgMy/G+M4MhIVX2eF4+S8yrzj8lHnT7lQk/I5jLHVsIrGKsQDuq65HwhV354/5BawFTim1M0UkmQGLFJeZB2HkpPpO0rVLfDjDfa/hkysny1xy/DHOL3hGJTNIWLZnLfvZ7Yuo3JbnQE8xNQa65NPAawaO9ryXFXwvZrWFEwXKQuxluz9AdR7zYcDQmLHVqWUNqXDmV+P/PgoOfKBfpEUszu7J/VztK2mtmMwhVJIJfrh5pAQcn3tRq03cXXcWmLlh5I6KUlPuwM/SOLwj1jbAWxTYGyoWLgn6yslCYmrS4vOFNj03O6xmRyjF5gTXVhoT0iWGC64JYWDQe0LcjmfONFgmTFCWbXzE9Z8hyHrjxfzzv9cFsSR+iAcssu+ht4poevanxs2+Hp/CMHPimw=
I have a list of segments and want to determine where and with what
other segments they are intersecting unsing the sweep algorithm.
The part for obtaining the intersection positions is straight forward
from the tutorial / example.
https://doc.cgal.org/latest/Surface_sweep_2/index.html
What steps would I have to take to obtain the the segments/curves
involed in the intersection?
Kind Regards,
Benjamin
