cgal-discuss - Re: [cgal-discuss] Creating Delaunay 3d triangulation with a circumradius bound
  • To:
  • Subject: Re: [cgal-discuss] Creating Delaunay 3d triangulation with a circumradius bound
  • Date: Fri, 27 Jul 2018 01:49:34 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi Sebastien,
thank you for the suggestion. Sadly I cannot, as the triangulation is an
initial configuration for an MCMC
<https://en.wikipedia.org/wiki/Markov_chain_Monte_Carlo> algorithm which
attempts to converge to a regular triangulation with certain properties (but
has to start with certain properties for it to work, too).
However, I have realized that a simpler solution might be to create a point
pattern such that the resulting tetrahedra are regular (as in made of
equilateral triangles), a 3d version of the equilateral triangle tiling
<http://gwydir.demon.co.uk/jo/tess/bigtri.htm> .
I am not able to test it now, but I will report back once I do. In the
meantime, other suggestions are definitely welcome.
