cgal-discuss - Re: [cgal-discuss] Resize Scene_plane_item
  • To:
  • Subject: Re: [cgal-discuss] Resize Scene_plane_item
  • Date: Fri, 27 Jul 2018 09:00:37 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Look at the function compute_normals_and_vertices() in the .cpp file pointed out.
Sebastien.
On 07/20/2018 05:17 PM, Annie-Pier L. wrote:
Hi,
I'm using the Scene_plane_item and I want to resize (reduce the surface) of
the plane that I display.
Is there a way to do it?
Here is the scene_plane_item.h:
https://github.com/CGAL/cgal/blob/master/Polyhedron/demo/Polyhedron/Scene_plane_item.h
Here is the scene_plane_item.cpp:
https://github.com/CGAL/cgal/blob/master/Polyhedron/demo/Polyhedron/Scene_plane_item.cpp
Thanks,
Annie-Pier Lavalleé,
Master student
