cgal-discuss - [cgal-discuss] Get boundary points using Basic Alpha Shapes 2d
  • To: cgal-discuss <>
  • Subject: [cgal-discuss] Get boundary points using Basic Alpha Shapes 2d
  • Date: Sun, 29 Jul 2018 23:08:20 +0800 (GMT+08:00)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi everyone,
I use Basic Alpha Shapes to get boundary points from some 2d points. As shown in attachments, boundary points like a  rectangle is what I want to get. But I failed. Through seeing demo about Alpha_shapes_2, I think that I maybe set a wrong Alpha. I hope that you can give me some suggestions so that I can get correct result.
The wrong boundary points is result of the following code.
  1. typedef CGAL::Exact_predicates_inexact_constructions_kernel  K;
  2.
  3. typedef K::FT                                                FT;
  4. typedef K::Point_2                                           Point;
  5. typedef K::Segment_2                                         Segment;
  6.
  7. typedef CGAL::Alpha_shape_vertex_base_2<K>                   Vb;
  8. typedef CGAL::Alpha_shape_face_base_2<K>                     Fb;
  9. typedef CGAL::Triangulation_data_structure_2<Vb,Fb>          Tds;
  10. typedef CGAL::Delaunay_triangulation_2<K,Tds>                Triangulation_2;
  11. typedef CGAL::Alpha_shape_2<Triangulation_2>                 Alpha_shape_2;
  12.
  13. typedef Alpha_shape_2::Alpha_shape_edges_iterator            Alpha_shape_edges_iterator;
  14.
  15.
  16. template <class OutputIterator>
  17. void alpha_edges( const Alpha_shape_2& A, OutputIterator out)
  18. {
  19.   Alpha_shape_edges_iterator it = A.alpha_shape_edges_begin(),
  20.                              end = A.alpha_shape_edges_end();
  21.
  22.   for (; it != end; ++it)
  23.     out++ = A.segment(*it);
  24.
  25. }
  26.
  27. bool file_input(std::list<Point> &points)
  28. {
  29.     std::ifstream is("J:\\General_Random_points2D.pts", std::ios::in);
  30.   if(is.fail())
  31.   {
  32.     std::cerr << "unable to open file for input" << std::endl;
  33.     return false;
  34.   }
  35.   Point p;
  36.   for (int i = 0; i < 2000; i++)
  37.   {
  38.       is >> p;
  39.       points.push_back(p);
  40.   }
  41.   CGAL::set_pretty_mode(std::cout);
  42.   std::cout << p << std::endl;
  43.
  44.   return true;
  45. }
  46.
  47. // Reads a list of points and returns a list of segments
  48. // corresponding to the Alpha shape.
  49. int main()
  50. {
  51.   std::list<Point> points;
  52.   if(! file_input(points))
  53.     return -1;
  54.
  55.   Alpha_shape_2 A(points.begin(), points.end(),
  56.                   FT(10000),
  57.                   Alpha_shape_2::GENERAL);
  58.   std::vector<Segment> segments;
  59.   alpha_edges(A, std::back_inserter(segments));
  60.
  61.
  62.   std::ofstream of("vertix.pts");
  63.   CGAL::set_ascii_mode(of);
  64.
  65.   CGAL::set_pretty_mode(std::cout);
  66.   for (int i = 0; i < segments.size(); i++)
  67.   {
  68.       of << segments[i].vertex(1) << std::endl << segments[i].vertex(2) << std::endl;
  69.   }
  70.   std::cout << "Alpha Shape computed" << std::endl;
  71.   std::cout << segments.size() << " alpha shape edges" << std::endl;
  72.   std::cout << "Optimal alpha: " << *A.find_optimal_alpha(1)<<std::endl;
  73.   system("pause");
  74.   return 0;
  75. }
Thank you, in advance. I will be honored to receive your help.
bingxin
发自网易邮箱大师
Attachment: boundary_points.png
Description: PNG image
