cgal-discuss - Re: [cgal-discuss] Does maximum Alphalevel always guarantee that all of the elements are classified as EXTERIOR type?
  • To:
  • Subject: Re: [cgal-discuss] Does maximum Alphalevel always guarantee that all of the elements are classified as EXTERIOR type?
  • Date: Tue, 7 Aug 2018 10:05:48 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:1MYiKRDvUf22UDiq1JXtUyQJP3N1i/DPJgcQr6AfoPdwSPT9psbcNUDSrc9gkEXOFd2Cra4c1ayO6+jJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglUhTexe69+IAmrpgjNq8cahpdvJLwswRXTuHtIfOpWxWJsJV2Nmhv3+9m98p1+/SlOovwt78FPX7n0cKQ+VrxYES8pM3sp683xtBnMVhWA630BWWgLiBVIAgzF7BbnXpfttybxq+Rw1DWGMcDwULs7Xiiv4qlpRRLmkSsLKzE0+3zThsFwkK5XpRSsrAF9zYHJeoGYLOdwcL3Tfd0aRmRPUMheWCNDDYygYIUCFPYBMORCooXhu1cDoxmzCA+xD+3v0D9IgXr20LU93es7Dw7G2BErEtULsHvOstr1ML0eUfqyzKnVwjTMcfdW1S356IfSaR8uuu+DUKl/ccXPzkkvEh3KjkmKqY3lMTOazPgCs3Sc7+p6VeOjkXIoqwZ0ojW2wMonl4fHhoUQyl/e9CV5xp44JduiR0FgetGkFIVfuzuGOItxR8MvRXxjtiUiyrAetpO2fTIGxIk7yxPfcfCKc4aF7gj+WOufPzt0nHZodK6lixux8EWs0O7xW8au3FtFsCZIlMTHuGoX2BzJ8MeHT+Nw/ke/1jaL0ADe8uBJLVoxlarcNpIswL09moAWsUvZHy/2nFz6jKiLdkU44OSo7PrnYrX8qp+aKYB0lhnyMqUomsOhHeQ1KgcDUmmB9eihyLHu/Vf1TbVEg/Esj6XUvo7WKdwepqGjAg9V1ogj6wy4DzejyNkYmGMII0xBeB6dlYjpPEzOIf/mAve7mVislC1kyOvdMbL/GZjNIWbMkLDkfblj905c0goyzd5F6J1IFrEBJ+jzW0/ruNPECR85NhS4w/z7B9VlyoMeRWWPD7eFP6Pdq1CI4vsjLPSNZI8OpDn9NuMl5+X1gH8imV4deLGp0oENZHC5GPRmOUSZbmD2jtcPC2dZ9jY5GeflgVnHXT9IbGupRIo94Cs6AcSoF9TtXIeo1ZmI0SPzSphfa2QAEFeRAXrsMYGNUf0BQC2fJcpsjiYVW7GqV4g7xFelswqsmOkvFfbd5iBN7cGr79Ny/eCGyElrpG5ESv+F2mTIdFla22YBRjs4xqd6+xUvxVqE1KVkme1WHNdP4OlYFAw9MMyElrAoO5XJQgvEO+yxZhO+WNz8WGM+Q9U0zsMUckh0EMmllAGF1C2vUedMyu67Qacs+6eZ5EDfYsZwz3Gcivt/yVwhG5Qfc2ivh6o68BXPQYnXkwOfmrr4Lak=
Hello,
Thanks for the data set. I can't reproduce the issue neither with the 4.6 release nor with CGAL's master branch. I do get the 545 faces, but they're all marked as 'interior' for the max alpha value (~1e14).
It's probably a good idea to update your version of CGAL in any case as 4.6 is a couple years old and there have been bug fixes and new features in Alpha_shape_2 and in other packages.
Best,
Mael
On 07/08/18 06:51, nsoonhui wrote:
Hi, I attach my dataset ( note that it is in Point3D format, but it shouldn't
matter as the z is 0 always and you can easily convert to Point2D).
And this is the gist of my code:
typedef CGAL::Triangulation_vertex_base_2<Kernel> VbT;
typedef CGAL::Triangulation_face_base_with_info_2<FaceInfo2,Kernel> Fbb;
typedef CGAL::Constrained_triangulation_face_base_2<Kernel,Fbb> FbT;
typedef CGAL::Triangulation_data_structure_2<VbT,FbT> TDS;
typedef CGAL::Exact_predicates_tag Itag;
typedef CGAL::Constrained_Delaunay_triangulation_2<Kernel, TDS, Itag> CDT;
typedef CGAL::Alpha_shape_vertex_base_2<Kernel> Vb;
typedef CGAL::Alpha_shape_face_base_2<Kernel> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb,Fb> Tds;
typedef CGAL::Delaunay_triangulation_2<Kernel,Tds> Alpha_Triangulation_2;
typedef CGAL::Alpha_shape_2<Alpha_Triangulation_2> Alpha_shape_2;
Alpha_shape_2 *A =new Alpha_shape_2(first,last, 100000,Mode.Regular);
auto maxLevel = A->number_of_alphas()-1;
auto alphaLevel = A->get_nth_alpha(maxLevel);
int i=0;
for(fit=A->finite_faces_begin(); fit!=A->finite_faces_end(); ++fit)
A->set_alpha(alphaLevel);
auto classType2 = A->classify(fit); //i==504 is
EXTERIOR
i++;
From what I can tell, there is an element at i==504, which is EXTERIOR. (
there are 545 elements).
Do let me know whether you can reproduce the problem with the dataset and
the above pseudo code. If not I will prepare a fully working sample.
I am using CGAL 4.6.2. Not sure whether it matters or not
coordinate.csv
<http://cgal-discuss.949826.n4.nabble.com/file/t212754/coordinate.csv>
