Re: [cgal-discuss] How to get order of intersection points that create and remove after moving a circular object in arrangement?
- To:
- Subject: Re: [cgal-discuss] How to get order of intersection points that create and remove after moving a circular object in arrangement?
- Date: Mon, 13 Aug 2018 09:28:00 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Use, what we refer to as, observers; see the example program examples/Arrangement_on_surface_2/observer.cpp and the doc. at https://doc.cgal.org/latest/Arrangement_on_surface_2/classCGAL_1_1Arr__observer.html
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
On 12 August 2018 at 12:28, Morteza Manavi <> wrote:
I want to get the sequence of events or intersection points that created and removed in the arrangement after moving a circular object form one position to another and I don't know how to do this using CGAL lib.
- [cgal-discuss] How to get order of intersection points that create and remove after moving a circular object in arrangement?, Morteza Manavi, 08/12/2018
- Re: [cgal-discuss] How to get order of intersection points that create and remove after moving a circular object in arrangement?, Efi Fogel, 08/13/2018
