cgal-discuss - [cgal-discuss] Iterate on the vertices of a skeleton in order
  • To:
  • Subject: [cgal-discuss] Iterate on the vertices of a skeleton in order
  • Date: Thu, 13 Sep 2018 11:10:20 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi,
Is there a way to iterate over vertices of a skeleton in order? I'm trying
with this code but the outputs points are not in order:
typedef CGAL::Mean_curvature_flow_skeletonization<Polyhedron>
Skeletonization;
typedef Skeletonization::Skeleton Skeleton;
typedef Skeleton::vertex_descriptor
Skeleton_vertex;
Skeleton skeleton;
CGAL::extract_mean_curvature_flow_skeleton(*mesh, skeleton);
BOOST_FOREACH(Skeleton_vertex v, vertices(skeleton) )
const Point& pts = skeleton[v].point;
skel_pt.push_back(pts);
thanks!
