cgal-discuss - Re: [cgal-discuss] Convert arrangement output point
  • To:
  • Subject: Re: [cgal-discuss] Convert arrangement output point
  • Date: Mon, 17 Sep 2018 10:38:49 +0430
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Thank you very much.
On Mon, Sep 17, 2018 at 1:11 AM Efi Fogel <> wrote:
Theoretically, you can define the number type of a kernel to be whatever you want, but if the number type has limitations so does the kernel defined with this number type.
Sqrt_extension is an algebraic number type (It can be used to represent algebraic numbers that are not rational) that supports certain operations in an efficient way and does not support at all other operations.
A Sqrt_extension number is represented by 3 rational numbers, namely a, b, and c, and its value is (a * b * sqrt(c)).
For example. you can add 2 Sqrt_extension numbers n1 = (a1, b1, c1) and n2 = (a2, b2, c2) only if (c1 == c2) or (b1 == b2 == 0).
The Arr_circle_segment_traits_2 traits uses the fact that Sqrt_extension is an algebraic number type (cause, for example, the coordinates of an intersection point of a segment and a circle might be algebraic).
However, it is limited (as explained above).
So you have two reasonable options: either use it, exploit its high performance, but stick to the rules of Arr_circle_segment_traits_2 or use something else.
   ____  _        ____             _
  /_____/_) o    /__________  __  //
 (____ (   (    (    (_/ (_/-(-'_(/
                         _/
On Sun, 16 Sep 2018 at 17:02, Morteza Manavi <> wrote:
Thanks Efi,
Is it possible to define Kernel such that accept Sqrt_extension coordinates as input?
On Sun, Sep 16, 2018 at 5:26 PM Efi Fogel <> wrote:
If you absolutely need to use a vertex position as a circle center, you cannot use Arr_circle_segment_traits_2.
In this case you need to resort to a more "powerful" traits, such as the Arr_algebraic_segment_traits_2 traits.
Sqrt_extension
cannot be converted to Rational without loss of data.
Naturally, managing, for example, segments, by the Arr_algebraic_segment_traits_2 is more time-consuming then by the Arr_circle_segment_traits_2.
So, make sure that the above is a must. (That is, circle centers may need to have Sqrt_extension coordinates.)
For example, consider a point p = (x,y) with Sqrt_extension coordinates that lies on some circle C.
You can approximating p with p' = (x', y'), such that p' also lies on C while bounding the difference between p and p'; see, e.g.,  CGAL::rational_rotation_approximation().
   ____  _        ____             _
                         _/
Sqrt_extension
Naturally, managing, e.g., segments, by the Arr_algebraic_segment_traits_2 is less efficient then by the Arr_circle_segment_traits_2.
So, make sure that the above is a must. For example
   ____  _        ____             _
                         _/
On Sun, 16 Sep 2018 at 13:36, Morteza Manavi <> wrote:
Hi,
I define arrangement:
typedef CGAL::Cartesian<CGAL::Exact_rational>                   Kernel;
typedef Kernel::Circle_2                                        Circle_2;
typedef CGAL::Arr_circle_segment_traits_2<Kernel>               Traits_2;
typedef CGAL::Arrangement_with_history_2<Traits_2>              Arr_with_hist_2;
and I want to get a vertex position and use it for creation new circle in the arrangement but I should use a Point with rational type as circle position while the type of vertex position is
Sqrt_extension and CGAL do not convert Sqrt_extension to Rational. Now I do not know how to convert Sqrt_extension to Rational such that do not loss data.(convert exactly)
