- To:
- Subject: [cgal-discuss] CGAL QP solver versus Matlab quadprog()
- Date: Sat, 29 Sep 2018 10:46:41 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Dear all,
I am finding that CGAL returns INFEASIBLE for a problem that Matlab
quadprog() can solve. I do not know if this is normal, or I am making a
mistake somewhere. I leave here the input of the program and would
appreciate if anyone can give me a hint.
BR
Daniel
Input of the program
D
D[0][0]=0.000050
D[0][1]=0.000050
D[0][2]=0.000000
D[0][3]=0.000000
D[1][0]=0.000050
D[1][1]=0.000050
D[1][2]=0.000000
D[1][3]=0.000000
D[2][0]=0.000000
D[2][1]=0.000000
D[2][2]=0.000050
D[2][3]=0.000050
D[3][0]=0.000000
D[3][1]=0.000000
D[3][2]=0.000050
D[3][3]=0.000050
c:
c[0][0]=-0.002359
c[1][0]=-0.002359
c[2][0]=-0.002399
c[3][0]=-0.002399
A:
A[0][0]=1.000000
A[0][1]=0.000000
A[0][2]=1.000000
A[0][3]=0.000000
A[1][0]=0.000000
A[1][1]=1.000000
A[1][2]=0.000000
A[1][3]=1.000000
b:
b[0][0]=1.000000
b[1][0]=1.000000
ub:
ub[0][0]=0.914808
ub[1][0]=0.933087
ub[2][0]=1.061726
ub[3][0]=1.028364
lb:
lb[0][0]=0.000000
lb[1][0]=0.000000
lb[2][0]=0.000000
lb[3][0]=0.000000
The problem has equality constraints. Matlab quadprog() returns the
following solution:
Cost function
fval:[0][0]=-0.004717
x:
x[0][0]=0.293237
x[1][0]=0.306496
x[2][0]=0.706763
x[3][0]=0.693504
I configure the program in CGAL as follows:
// choose exact integral type
#ifdef CGAL_USE_GMP
#include <CGAL/Gmpzf.h>
typedef CGAL::Gmpzf ET;
#else
#include <CGAL/MP_Float.h>
typedef CGAL::MP_Float ET;
#endif
// program and solution types
typedef CGAL::Quadratic_program<double> Program;
typedef CGAL::Quadratic_program_solution<ET> Solution;
Solution s = CGAL::solve_quadratic_program(qp, ET());
- [cgal-discuss] CGAL QP solver versus Matlab quadprog(), DaniCamps, 09/29/2018
- Re: [cgal-discuss] CGAL QP solver versus Matlab quadprog(), DaniCamps, 09/30/2018
