Re: [cgal-discuss] CGAL 4.13 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] CGAL 4.13 Released, Computational Geometry Algorithms Library
- Date: Tue, 2 Oct 2018 20:08:42 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
On 10/1/18 2:47 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
The CGAL Open Source Project is pleased to announce the release 4.13
of CGAL, the Computational Geometry Algorithms Library.
Debian packages for CGAL 4.13 are now available as well. Simply add
deb http://debian.cgal.org stretch main
deb-src http://debian.cgal.org stretch main
deb http://debian.cgal.org buster main
deb-src http://debian.cgal.org buster main
to /etc/apt/sources.list (you only need the pair of lines corresponding
to the release you are using). For sid/unstable, packages are available
from the official Debian repository. The packages are called libcgal13,
libcgal-dev, libcgal-qt5-13, libcgal-qt5-dev, libcgal-demo, and
libcgal-ipelets.
In case you want to download the packages manually, have a look at
https://debian.cgal.org/pool/main/c/cgal/ .
See also https://www.cgal.org/FAQ.html#debian_packages .
Best regards,
Joachim
- [cgal-discuss] CGAL 4.13 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 10/01/2018
- Re: [cgal-discuss] CGAL 4.13 Released, Computational Geometry Algorithms Library, Joachim Reichel, 10/02/2018
