cgal-discuss - Re: [cgal-discuss] is there a vtk-to-CGAL converter?
  • To:
  • Subject: Re: [cgal-discuss] is there a vtk-to-CGAL converter?
  • Date: Thu, 4 Oct 2018 12:16:56 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
You can include the converters with
#include <CGAL/IO/Complex_2_in_triangulation_3_to_vtk.h>
#include <CGAL/IO/Complex_3_in_triangulation_3_to_vtk.h>
The entire CGAL/IO folder in your installation is very useful, if not always
well-documented.
Also, I've taken to using Meshlab ( http://www.meshlab.net/ ) for viewing
OFF formats ("native" to CGAL). The tool meshlabserver (installed with
meshlab) is also good for converting file formats. You may find it handy.
Note that if you do decide to install meshlab, the binaries can be found in
the folder src/distrib/, for some reason...
David
  • Re: [cgal-discuss] is there a vtk-to-CGAL converter?, dlenz, 10/04/2018
