cgal-discuss - [cgal-discuss] Option to suppress insertion of points on border when meshing?
  • To:
  • Subject: [cgal-discuss] Option to suppress insertion of points on border when meshing?
  • Date: Mon, 29 Oct 2018 07:49:39 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hello,
When meshing using the Delaunay_mesher_2, is there a way to suppress
insertion of points along the external border, or constraining segments ing
general, like the Triangle library (Shewchuk) does with the -Y switch?
Thanks,
Erik
  • [cgal-discuss] Option to suppress insertion of points on border when meshing?, ecu, 10/29/2018
