- To: "" <>
- Subject: Re: [cgal-discuss] How to get adjacent vertices in 3d triangulation
- Date: Sat, 3 Nov 2018 20:22:59 +0000 (UTC)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Thanks Mael,
This solved my problem!
James,
On Thursday, November 1, 2018 12:53 PM, Mael <> wrote:
Hello,
A good idea when wondering how to actually use a function of CGAL
that you have found in the doc is to search the code of CGAL for
real usages of that function (either grepping the source, or using
the search function on github).
For example, https://github.com/CGAL/cgal/search?p=1&q=adjacent_vertices&unscoped_q=adjacent_vertices
here is the result of the search, and you can find this
piece of code, which illustrates a call to adjacent_vertices with
a 3D periodic triangulation: you create a container (here a
vector) and pass as parameters both the vertex whose adjacent
vertices you want to collect, and an inserter to the container
(here using std::back_inserter()
to create such inserter).
Your container is then filled by the function with the adjacent
vertices of the vertex passed as a parameter and you can use them
as you desire afterwards.
Does this clarify things for you?
Best,
Mael
Mael
On 2018-11-01 17:25, GAD FLY wrote:
Hi all,
Can anybody help
me to use the adjacent_vertices() function in 3d
triangulation adjacent_vertices() with a simple
example?
Thanks,
James
- [cgal-discuss] How to get adjacent vertices in 3d triangulation, GAD FLY, 11/01/2018
- Re: [cgal-discuss] How to get adjacent vertices in 3d triangulation, Mael, 11/01/2018
- Re: [cgal-discuss] How to get adjacent vertices in 3d triangulation, GAD FLY, 11/03/2018
