cgal-discuss - Re: [cgal-discuss] Plotting a mesh: Geom_traits with Triangulation_data_structure_2
  • To:
  • Subject: Re: [cgal-discuss] Plotting a mesh: Geom_traits with Triangulation_data_structure_2
  • Date: Tue, 13 Nov 2018 12:17:03 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=Pass
  • Ironport-phdr: 9a23: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
Hello everybody out there!
If I understand the documentation, CGAL does not provide any way to
draw a “Triangulation_data_structure_2”. I think I should use my
“Triangulation_data_structure_2” to build a “Delaunay_triangulation_2”.
The thing is, I do not find any way in the documentation to do such thing.
Does somebody have some example on building a
“Delaunay_triangulation_2” using an existing “Triangulation_data_structure”?
Best regards.
Yoann LE BARS
http://le-bars.net/yoann
*Diaspora :
