cgal-discuss - Re: [cgal-discuss] 3D Surface Meshing from Point Cloud with Edge Constraints
  • To:
  • Subject: Re: [cgal-discuss] 3D Surface Meshing from Point Cloud with Edge Constraints
  • Date: Fri, 16 Nov 2018 10:18:26 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
  • Ironport-phdr: 9a23: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
On Friday, November 16, 2018 3:32:11 AM CET williamlai3a wrote:
> Hi All,
> I would like to generate a 3D 2-manifold (no need to be closed) from a given
> 3D point set and a given 3D line (edge) segments. I want the resulting mesh
> to take the 3D line segments to be edges as many as possible.
> >From my understanding, 3D Delaunay Triangulation cannot impose boundary
> >hard
> constraint.
> Would the 3D mesh generation concept be able to help me in this case?
> If yes, how could I make use of it?
> If no, would you please advise whether CGAL allows me to do that?
It looks like more a reconstruction problem than a meshing problem. I suggest
you send us a characteristic data set showing what you have in input.
(Please do not attach to a mail, but links to a web service, like gist,
Google
Drive, or any another one.)
Laurent Rineau, PhD
