- To:
- Subject: [cgal-discuss] vtk libraries
- Date: Sat, 8 Dec 2018 13:52:57 -0600 (CST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
I installed 4.13 on Ubuntu 18.04.
VTK is not found when running relevant demos/examples: VTK was not
found during installation of 4.13 (per my reading of CMakeCache.txt).
VTK libraries are installed:
apt list --installed | grep vtk
libvtk6.3/bionic,now 6.3.0+dfsg1-11build1 amd64 [installed,automatic]
libvtk6.3-qt/bionic,now 6.3.0+dfsg1-11build1 amd64 [installed,automatic]
python-vtk6/bionic,now 6.3.0+dfsg1-11build1 amd64 [installed,automatic]
______
(Among the dozens of files that include vtk in their names.)
How do I get CGAL to use an installed version of VTK? Or how do I install
a version of VTK that will work with 4.13?
I hope the solution will not interfere with my use of paraview (5.4.1 64
bit),
which is why I want to have CGAL generate VTK files.
Thanks,
Tim
- [cgal-discuss] vtk libraries, Dr01TSPC, 12/08/2018
- Re: [cgal-discuss] vtk libraries, Marc Glisse, 12/08/2018
- Re: [cgal-discuss] vtk libraries, Dr01TSPC, 12/11/2018
