cgal-discuss - Re: [cgal-discuss] Faces listed twice in output mesh files of example mesh_polyhedral_domain
  • To:
  • Subject: Re: [cgal-discuss] Faces listed twice in output mesh files of example mesh_polyhedral_domain
  • Date: Wed, 12 Dec 2018 11:13:39 -0600 (CST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Sebastien:
Thank you for the hint. Is there a good place to put
CGAL::Mesh_3::output_to_medit<C3T3, true, false>(ostream, c3t3);
in mesh_polyhedra_domain?
I am very new to CGAL and new to c++.
JUST to be sure. I have seen color info in medit files - following tri info
on each line.
The out put files from mesh_polyhedral_domain have two lines duplicated -
no new info. A section of the Triangles section of an output mesh file is:
Triangles
3032
14 370 228 1
14 370 228 1
129 106 347 1
129 106 347 1
51 149 231 1
51 149 231 1
311 88 513 1
311 88 513 1
237 197 190 1
237 197 190 1
179 187 199 1
Regards,
Tim
